Introduction: A Simple RGB LED Cube 2X2X2
This project is an RGB LED Cube because it lets to you multiply the amount of colors that you obtain from a cube using 14 outputs from an Arduino uno so you use 12 outputs to control the LEDs and 2 outputs for controling the cube's planes through 2 resistors of 100 Ohm. For uploading the code, go to the following website: http://pastebin.com/Vt96H2pi
Step 1: Bill of Materials
What you will need:
1 Arduino Uno
1 PCB for Arduino
8 Common cathode RGB LEDs
2 100 Ohm resistor
1 #22 copper wire (1 meter)
1 Heat Shrink Tube (1meter)
1 40-pin array for Arduino shield
1 Solder Roll
1 Soldering station
Step 2: Schematic
The diagram of your project is the most important thiing that you should take accounting so that you have success and can work without any problem. Follow carefully the schematic!!!!
Step 3: Assembling the Project
Assemble your project carefully so that you don't have any problem in each step and can enjoy it once concluded. Good Luck with your project. You have a great partner with the schematic of your project.
Step 4: Completing the Project
Complete your project.
Step 5: Uploading the Code
Once completed the project, visit: http://pastebin.com
Then, upload the code from http://pastebin.com/Vt96H2pi
Enjoy the project if you did everything well!!
