Introduction: AIR HOCKEY AND CHILL
Building this improved and enhanced table is very easy. All that need to happen is to replace the fan system and put in some posts on the corners.
Step 1: Replace Fan
Take out the stock fan and install a leaf blower as a new air source. This will make the airflow stronger and come out of the holes on top faster.
Step 2: Create Space for Corner Posts
Take out enough of the corners of the table to fit a railing post or pole to install. First nail a screw or nail in the corner for initial support.
Step 3: Install Posts
Install posts on to the corners with hot clue.
Step 4: PVC Supports
Slide down sawed off pvc tubes slightly wider than the poles. This adds more support for the poles to stand upright.
Step 5: Finished
After all these steps have been completed then you now have an improved and more useful table to play on. The air will be stronger and the posts are a great place to attach plates anything to hang or hold while you play hockey.
