Introduction: Accelerator Pedal Position Sensor
APPS (Acceleration pedal position sensor) is a PCB created as part of the electrical car
assembled by PUT Motorsport - a Formula Student team from Poznań University of
Technology.
APPS is a part required by the competition rules. Its main purpose is to analyze signals
coming from two potentiometers mounted along the acceleration pedal and to decide
whether the measurements are plausible or not. An implausibility of the signals is defined as
deviation of more than ten percentage points pedal travel between any of the used sensors.
By design the APPS signals must have different, non-intersecting transfer functions. Thus
we chose to use two potentiometers with linear transfer functions offset by a voltage divider.
Step 1: Features:
Main features included on the board are:
- pedal position readout
- sensor power delivery
- plausibility checks
- CAN bus interface
- pinout interface compatible with other PCBs
- shutdown circuit relay
Step 2: Sensor Power Delivery
Each of APPSs potentiometers has to have a separate power source
Step 3: Sensor Signal Measurement
Each signal from the potentiometers is passed through a low pass filter designed to cutoff
frequencies above 338 Hz. After the signal has been filtered it is led to an ADC of STM32.
Step 4: CAN Interface
Our car uses CAN bus for device communication. APPS sends current pedal position over
the bus as well as diagnostic information regarding any errors that occurred during its
operation.
Step 5: Front-box Pinout Interface
APPS is a part of the front-box - a PCB stack that’s located at the front of the car which we
already covered in this article - thus it has to follow a certain pinout that allows for easy
debugging and connection with other boards that’s space efficient and easy to disassemble.
Step 6: Manufacturing
Manufacturing
PCBs designed by our team are manufactured by JLCPCB - a hardware production
company that specializes in batch PCB production. You can create PCBs with up to six
layers, and order a batch size that fits your needs. Batch production is beneficial since
during PCB assembly, many things could go wrong and the board could get damaged, that’s
where excess copies come in handy. If unlike us you don’t enjoy assembling PCBs, JLCPCB
has got you covered as PCB assembly is also a part of their offer!
To order a PCB of your design, simply go to jlcpcb.com and click the “Instant quote” button.
You will be forwarded to the order editor where you’ll find plenty of options to customize your
batch of PCB to fully meet your needs. Firstly you’ll need to upload your gerber files archived
into .zip or .rar format. The preview as well as the summary view will change accordingly to options you have
chosen. Some of the options (like dimensions or layer number) will be pulled from the gerber
files you have uploaded. After you’ve customized the board, you can proceed to the checkout located at the right side
of the editor. Each and every board we’ve received from JLCPCB is of highest quality and we’ve always
enjoyed working with them!
