Introduction: Add NFC to Your Bluetooth Speakers!
Do you want to be able to share your BT speaker with your friends easily?
Do you hate connect your phone to your BT speaker as much as I do?
1. Going to settings
2. Turning your BT on
3. Search for devices
4. Select device
5. Connect to device
Bleeehhh! >:P
What if I told you you could do it in one step after this tutorial?
Or just wanna upgrade your (old) BT speaker; just because you can?? ;)
4. Select device
Bleeehhh! >:P
Step 1: Find Out Witch Type of NFC You Need.
I was looking for BT audio dongles for a friend of mine; a few had NFC; it made me think; how would such thing work?
Is it an active method? Or is it passive?
Hmmm..
I think I can do it passively!
Let's look on ebay.
I found out there where multiple types of NFC; different wavelength, different storage-size and different uses.
which one do I need?
I've found out that I need, and it's the: NXP MIFARE - NTAG213
Multiple forums state hey're the best allround choice for most mobile devices.
Hmmm..
Let's look on ebay.
Step 2: Purchasing.
I bought my NFC-tags on ebay.nl at 6 for €2,
but chances are, that you might find them somewhere China even cheaper ;')
Step 3: Writing the Tags.
Good options are: Trigger & NFC Tools.
My advice is; use em both, every time.
They both make your phone slightly react different; and the one time you like the one's app outcome more than the other.
(note: at the time that I actually made this i'ble this was the best way... since then the apps changed very much in a good way; so you might be good now with just one of them)
The programs are fairly easy to use :)
The're quite straight forward and no coding necessary; that has been done for you ^^
Just fiddle around a bit; and you'll get the hang off it easily :D
Step 4: Testing & Placing the Tag.
I thought;
"Let's put it behind the battery-lid for testing! :D "
Abd then I was all like;
"Ahw menn; why ain't it working :( "
Thus I've found out the hard way; these tags don't work on/near metal :\
There's probably a good scientific reason for; but I can tell you without these specifics; it won't work.
Step 5: 1st Contact.
When I used Trigger it only prompted me once.
Every other time after this; it will simply connect when tapping your tag; without any other button-clicking required! :D
Step 6: Done!
Enjoy your deserved laziness ;D
