Introduction: Adding a Current Limit Feature to a Buck/Boost Converter
About: Awesome Electronics Tutorials, Projects and How To´s
In this project we will have a closer look at a common buck/boost converter and create a small, additional circuit that adds a current limit feature to it. With it, the buck/boost converter can be used just like a variable lab bench power supply. Let's get started!
Step 1: Watch the Video!
The video gives you all information you need to recreate the circuit. In the next steps though, I will present you some additional information.
Step 2: Order Your Components!
Here you can find a parts list with example seller (affiliate links):
Aliexpress:
1x Buck/Boost Converter: https://s.click.aliexpress.com/e/_dTevK0K
1x LF33 Voltage Regulator: https://s.click.aliexpress.com/e/_dT0fKCw
1x 10nF Capacitor: https://s.click.aliexpress.com/e/_dU4FEsB
1x 10µF Capacitor: https://s.click.aliexpress.com/e/_d7dOwRz
1x 0.1Ω Current shunt: https://s.click.aliexpress.com/e/_dSyQdMA
2x 3.3kΩ, 2x 100kΩ Resistor: https://s.click.aliexpress.com/e/_dTPpXjt
1x MCP602 OpAmp: https://s.click.aliexpress.com/e/_dTvJRGw
1x 10kΩ Trimmer: https://s.click.aliexpress.com/e/_dTFyPv5
1x UF4007 Diode: https://s.click.aliexpress.com/e/_dYR45Bh
1x Voltage/Current Meter: https://s.click.aliexpress.com/e/_d8lymHM
Ebay:
1x Buck/Boost Converter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x LF33 Voltage Regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10nF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 0.1Ω Current shunt: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 3.3kΩ, 2x 100kΩ Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x MCP602 OpAmp: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 10kΩ Trimmer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x UF4007 Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Voltage/Current Meter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Buck/Boost Converter: http://amzn.to/2w1WgTz
1x LF33 Voltage Regulator: http://amzn.to/2w1f2dF
1x 10nF Capacitor: http://amzn.to/2xIowip
1x 10µF Capacitor: http://amzn.to/2habIql
1x 0.1Ω Current shunt: http://amzn.to/2haAOWd
2x 3.3kΩ, 2x 100kΩ Resistor: http://amzn.to/2w2jSaI
1x MCP602 OpAmp: http://amzn.to/2x61uBr
1x 10kΩ Trimmer: http://amzn.to/2x9NmVc
1x UF4007 Diode: http://amzn.to/2w2vzxU
1x Voltage/Current Meter: http://amzn.to/2xJ2YCt
Step 3: Create the Circuit!
Here you can find the schematic and pictures of my completed circuit. Use it as a reference to create your own.
A rather tricky part is the current path on the output side of the converter. If you want to hook up the current shunt and the V/I meter then your wiring should be like this: Out+ -->Load+ -->Load- --> Red Wire I Meter --> Black Wire I Meter --> Current Shunt 1 --> Current Shunt 2 --> Out-
Step 4: Success!
You did it! You just added a current limit feature to your Buck/Boost converter!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
