Introduction: Adjustable Pipe Roller and Transfer Wrench
About: An Production engineering student
If you have a problem to rolling and transfer the circular
sections(round pipe and shafts) without varying the centre with less friction these will find an suitable replacement for it.
I too have the same problem so I have made it. In 3rd Image you can see your conventional method used for these purpose. It can roll the section well but it can’t transfer and height adjustment also tough.
By using these wrench we can roll or transfer pipe of outer/shaft diameter 50mm to 300mm.
Step 1: Bill of Materials
Bill Of Materials
ALL DIMENSIONS ARE IN MM
Standard available materials
2002 Ball Transfer---------------- 2 pieces
Button head M6 x 25 bolt------ 6 pieces
(High Tension)
M6 Nut------------------------------ 6 pieces
25mm square clamp------------- 8 set
M10 x 35 M.S hex bolts--------- 16 pieces
(In some cases available with clamp)
M24 x 240 M.S hex bolts-------- 2 pieces
M24 M.S Nuts---------------------- 4 pieces(6 if lock nut is needed)
25 MM x 182 forged rod--------- 1 piece
Fabrication raw material
M.S hot rolled steel plates
10 x 100 x 252---------------------- 2 pieces
16 x 100 x 300---------------------- 2 pieces
16 x 100 x 300------------------------ 1 piece
10 x 300 x 450----------------------- 1 piece
10 x 300 x 350----------------------- 1 piece
Round section
Ø 50 length 48 M.S shaft--------- 2 pieces
Ø 24 length 40 M.S shaft--------- 4 pieces
Inner Ø 27 outer Ø 32 M.S Pipe-2 pieces
Square section
25 x 25 length 100 cold rolled M.S shaft------2 pieces
FOR EACH PART DETAILED DIAGRAM HAS BEEN ATTACHED.
Step 2: Part 1 Fabrication
Bend and drill the plates of dimension 10 x 100 x 252 as per
diagram.
Bore 26mm in 50 mm shaft.
Now Place the plate and shaft in the plate of dimension 16 x 100 x 300 and weld it.
2---- sets ( have to be prepared)
Step 3: Part 2 Fabrication
Take the plate 16 x 100 x 300 make the drill and bend.
After make the rivet at the holes with inner diameter of 26.
1----set ( have to be prepared)
Step 4: Part 3 Fabrication
An 25mm x 200 rod forged at an end and makes length of 182.
1---set ( have to be prepared)
Step 5: Part 4 Fabrication
An M24 nut has been taken both ends are welded with Ø24 x 40 rod.
Step 6: Part 5 Fabrication
Both ends of 25 x 25 shaft have machined to diameter of 24mm
length 30mm on each end.
And the pipe inner Ø 27 x outer Ø32 has to be welded at centre of the shaft.
Step 7: Part 6 Fabrication
The plate 10 x 300 x 450 slotted at both side of dimension
45 x 40 with fillet 10 and bended as per diagram.
Step 8: Part 7 Fabrication
Plate 10 x 300 x 350 has been chamfered at four corners.
1---set. ( have to be prepared)
Step 9: Assembly
1) & 2.)Ball transfer has been mounted on part 1 and fastened.
3 )Part 1 get mate with hole provision of part 2 and pivoted using part 3.
4.)Part 5 get assembled with 25mm square clamp as dimension shown in diagram. square clamp welded with part
5.)At both ends of part 6 square clamp welded as per dimensions shown in diagram and part 4 assemble with the square clamp.
6.)Part 6 and part 7 are welded as mate in the diagram.
Step 10: Finished
Now it ready you load pipe of outer diameter from 50mm to 300mm.
