Introduction: Air Fort
This is a quick Instructable on how to create an Air Fort. An Air Fort is a fort that is supported completely by air.
Air forts also have a green side. The fort uses very little air so it does not take a large fan to keep it inflated. The low power fan keeps the fort very cold. It is almost like a mini air conditioned room.
Step 1: Supplies
For this Instructable you will need:
A bed
A sheet larger than your bed(I use a sheet from my parents bed).
Clamps(to attach blankets to the bed).
Tape(duck tape or packing tape work best).
A fan
You do not need the bed or clamps if you don't have them. I recommend using a bed because it is easier but if you want you could just tape the sheet to the floor.
A bed
A fan
Step 2: Step 1...The First Real Step
The first step is to take your sheet and lay it out on your bed (or floor). Next set your fan up on one side of your bed.
Step 3: Tape!
Next, take the end of the sheet and attach it to the fan using tape. Look at the picture for help.
After you attach your sheet turn on the fan. The fort should inflate a little.
At this point you should have the sheet only attached to the fan and the fan turned on.
Step 4: Leaks...
Then, climb inside your fort. Look for where the air leaks out. Take your clamps and close all the leaks (it may help if you tuck the sheet under your mattres).
Step 5: Almost Done! Step 4
The last step is the hardest. You must add a door. Doors are very tricky.
Undo one of your clamps. Instead of attaching the clamp to the bed just attach it to the sheet. The weight of the clamp will hold the sheet down.
If anything was unclear just let me know.
Thanks....
Thanks....
