Introduction: Airsoft Grenade
About: I like fun stuff, deadly weapons and non deadly weapons, that should explain all you need to know.
Hi, this is my first Instructable and it is a fairly simple recipe for making an air soft grenade, you will need: Baking soda, Vinegar, a Ziploc bag, scissors, a spoon, air soft bbs(optional) and a water bottle preferably a thin one such as crystal geyser or nestle pure life, also I recommend eye protection.
* Please note i am not responsible for you or your actions, if you hurt yourself or others don't blame me.*
Step 1: Materials
Any type of vinegar should do, i recommend a thin plastic water bottle such as Crystal Geyser or Nestle pure life bottles.
Step 2:
First empty your water bottle, by either drinking it, Yea, or dumping it out on the ground, no. Then insert as many bbs as you want. then mark about half way up your bottle and fill it with vinegar to your mark.
Step 3:
Next cut the zipper off your plastic bag, then carefully take the bag, not the zipper, and insert it into your water bottle of vinegar but not all the way leave the opening to the bag and stretch it over the side of the water bottle, do not let the bag fall in!
Step 4:
Next put your baking soda into the bag using your spoon, i recommend 6 or 7 spoon fulls of baking soda, now is the most crucial part so do not let your bag fall in.
Step 5:
Next screw on your cap over a slim part of the bag for transporting small distances, if you are going to be running long distances i do not recommend leaving the bag in the bottle but instead inserting it when you are ready to use the grenade.
Step 6: Using Your Grenade
First put on your eye protection! Then to prime your grenade simply unscrew the cap and push the plastic bag into the bottle, then screw the cap back on tightly and shake the bottle a few times then throw it, it works best if you throw it against something hard, if it does not go off right away it will go off but it might take a while. I will be uploading a video of the grenade being used soon.
Like i said early this is my first instructable so if its awesome leave a comment if not i don't care.
