Introduction: Alaskan Pallet Planter
Do you have an old pallet lying around that you don't have a use for? Do you need a new outdoor rustic planter? Well try out the easy to make Alaskan Pallet Planter.
Step 1: Needs
Wooden Pallet
Hammer
Pry bar
Saw
Flex seal
Optional:
Sand paper
Paint
Step 2: Disassembling the Pallet
Remove 2nd and 3rd boards from one side of pallet.
Remove nails from boards carefully so they can be reused.
Step 3: Assembling the Sides of the Planter
Place one of the removed board against board 1.
Step 4: Reusing the Nails
Reuse nails to resecure board to pallet.
Step 5: Placing Bottom Board
Cut supports of pallet flush with newly assembled boards using a saw.
Place the last removed board on the end of the supports of the piece you just cut. Resecure this board using the removed nails.
Step 6: Finishing the Planter
Spray flex seal on inside of newly assembled planter to make it watertight.
Let dry.
Sand and decorate outside of planter as desired.
