Alien Queen - DIY Costume
ashleyjlong 'profile picture'
51K29071
Intro: Alien Queen - DIY Costume
Alien Queen interpretation -My Halloween costume effort for 2014.
STEP 1: the Inspiration
Movie monsters of the 1980’s and 90’s have been a huge influence on my personal artwork, and I wanted to make something BIG that I could use for both Halloween and Comic Con. The Alien Queen, from “Aliens 2,” is savage and frightening, but also had a lot of potential to be elegant. When I do a costume of an existing character, I like to put a little spin on it rather than going for something completely movie accurate. My Alien Queen is bejeweled, like royalty, and could be the center of attention at any cocktail party. Whether that’s because of her excellent taste in fashion, or her ability to dislodge a human head from it’s spine in under 5 seconds, really depends on the day.
*Note: I do not claim to own the image above, but included it as it was one of my main inspirational photos while working on this project.
STEP 2: The Pattern, or "I'm Bad at Math" or "Thanks, Internet"
The first step was to create a pattern for the headpiece. I started to map this out on tracing paper, but quickly realized I need to be way better at math to pattern something this large and this intricate. Fortunately, there are entire online communities dedicated to the Alien and Predator movies, wherein you can find 3-D models of the heads, armor, etc. for free use. Some amazing artist (if I can find the link again I will definitely be sending this person a thanks) modeled the Queen and converted it into a printable Pepakura pattern. For those who don’t know, Pepakura is the art of cutting, folding, and gluing paper to form 3-D objects. The pattern was printed flat on about 50-60 sheet of cardstock, which I X-acto cut and glued together over the next 2 months.
STEP 3: Make It Strong!
Once the Pepakura model was assembled, I glued several plastic drinking straws inside the head to act as vertical braces. This would ensure the head held its volume while being coated with a hardener, without adding the weight of a filler. I brushed on several thin layers of Bondo boat resin. It’s really magical stuff! It hardened the head model into a durable object; no more shifting around on the glued hinges. It also allowed me to keep the head hollow and lightweight for greater wearability.
ALWAYS work with resin outdoors, or in a well ventilated area. My boyfriend once tried doing a much smaller helmet in our downstairs bathroom and the fumes were so bad I was afraid our parrot was going to croak canary-in-a-coal-mine style! I went out on the balcony to use the resin, which not only dispersed the fumes, but I believe also contributed to quick and even drying. Once all the Bondo was dry, I used Free Form air clay from Smooth on to round out the dome of the head and some of the horns. I chose to keep the modern geometric look of the pepakura on the shield, but wanted the face to be smooth and organic. Adding water to the clay helped me get the look I wanted. Expect to spend some time sanding the resin and clay with a fine grain paper if you weren’t careful and smooth with your initial application.
STEP 4: Painting Choices
For the paint phase, I started with some medium gray primer, just to get a base going. I was really excited about the Rustoleum black “hammered” finish spray paint I bought, thinking it would be a little more organic –like insect armor- than regular gloss black. Honestly, I was a little disappointed with this stuff. The hammered finish was not very prominent, and the black looked more like gunmetal gray in the sun. I needed to darken it, but still didn’t want to go with cheap-o gloss black. I decided to try some black lens tint, usually used on car taillights, for a semi-transparent black gloss over the top. The lens tint was perfect! Slick coverage that gives a nice extra dimension to the color in the sun, and as simple to use as regular spray paint.
STEP 5: How Am I Going to Wear This??
Figuring out how to make this wearable was perhaps the most challenging part. I tried different fulcrum points and adding counterweight in the face to balance the shield. Purely through trial and error, I found the headspace that would be the most balanced and pretty much just crammed a black foam bike helmet in the hollow of the piece. After several tests to be sure of placement, I locked it in with E-6000 and Free form clay.
The photo here is some very early trial and error fitting. Ultimately it was better to go more horizontal and more central.
STEP 6: Jewels, Dahling!
Attaching the jewels was a surprisingly intense portion of the project. I knew I wanted the headpiece to be glamorous, but not gaudy. Before gluing the stones on, I plotted out my patterns by temporarily attaching them with removable poster putty. Then, one by one, I went back and traded poster putty for E-6000, placing each stone by hand. I decided to concentrate the jewels nearest the face, with a cresent above the head dome sort of where you might place a tiara. The stones on the shield are placed more sparsely, in clusters that felt organic (and fabulous). I found the dress at Goodwill and felt it worked well with my sparkly monochrome palette.
Fun Fact: If you look veeeeery closely at the final photos, you might see the tiny silver crown shaped gem on the front of the head dome.
STEP 7: Spine
Building the spine was pretty straightforward. A piece of flexible aluminum conduit makes a nice natural spine. I filled it with foam gap filler and held it into the curved shape I wanted until the foam expanded and hardened. When my arms got tired I placed it between two opposing heavy flower pots, to keep holding the curves for me. Once it was dry I spray painted it, then applied the vertebrae. Each vertebrae is made from 2 interlocking pieces of sheet foam. I made the pattern on paper (again, just trial and error) and then made a few different sizes based on the master. I used thin black elastic to make easy shoulder straps, but you could use any material that suits your costume if you like them more prominent.
STEP 8: Long Live the Queen!
I’m really thrilled with the end result and learned a ton of new materials knowledge along the way. Friends have been wowed by the photos so far and I can’t wait to get in front of some Halloween crowds. I've also built a paper mache alien egg to take with me to parties, full of green slime I’m going to flick at unsuspecting audience members/ victims!
Ripleys, face huggers, Colonial Marines --see you at the cons!!
70 Comments
Me puedes enviar las medidas de las piezas de la columna ? Gracias
Giger designs are quite sexy though...
Hi XenomorphLuver. You must be new to Instructables. This site is great because it has a Be Nice policy. Basically, if you don't have anything nice or constructive to say --move along. Also, this costume is not intended to be sexy. I mean...if this were supposed to be "sexy", wouldn't it be sort of a half measure? There's barely any skin exposed. This is simply a feminized interpretation of a great movie monster. All the rest of the 35k+ viewers seemed to understand and enjoy it. Sorry it wasn't your thing ! Can't wait to see what amazing costume you come up with ;)
HOLA ME PUEDES ENVIAR EL ARCHIVO EN PDO, PARA PEPEKURA AL CORREO RODRIGO.A.REYES.PINO@GMAIL.COM
fantastic work.
Thanks! Just mounted the head on the wall this weekend!
Nice Costume! I like how you put your own spin on it
Would you be able to link us to the original file please? lol i'm stringing up ideas to make for next week's halloween party. this could be a stretch to do in a matter of days....but we'll see. just trying to look for the right link. thank u
I'm working on trying to find it again, but since it came from a forum there's a LOT to sift through. No luck yet. If you just google something like "xenomorph pepkura pattern" you'll probably find all the same forums and might be able to dig out something accessible for a few days work. Based on my experience, this would take too long to be done in time for your party. However, other artists had made regular alien heads too, which were slightly smaller. There are also lots of great Predator masks out there and those seem way more do-able on a deadline!
If you're feeling super ambitious or have lots of help, this forum has a guy who made a true to life sized Queen based on a pattern! AMAZING! http://www.thehunterslair.com/topic/22195-new-predator-pepakura-armour-ready-for-download/page-29
i know! thank you for the words of encouragement and other alternative solutions! you're end result gave me a lot of ideas. i'll try to make due with what i can find in these thanks a lot for your speedy reply. this would be my first attempt at building something in general so looking forward to see if i can produce results. wish me luck!!
Just in case you still want the original pepakura file, I've reposted it online. The forum link I used is now dead. Check out my new Ible about the Pepakura process for the link! https://www.instructables.com/id/Pepakura-Alien-Queen/
I wanted the model to make the head and hang on the wall as a trophy!
That may be my plan after Halloween too! This thing is awfully big to store, so we thought maybe we'd mount it on the wall for people to enjoy.
Just need to find the model, something that has not yet managed to find
I finally re-posted the original pepakura file for the Alien and made a separate Ible about the paper process. https://www.instructables.com/id/Pepakura-Alien-Queen/
Stay tuned for a new Instructable in which I specifically discuss the pepakura part of the project (coming this week, I hope)! I finally located the forum thread where I originally found the pattern, but the link to the artist's original download was dead. I'll be doing exactly what you've suggested --uploading the file I have on my own machine so that people can have access again.
More Comments
