Introduction: Amazing a Measuring Worm From Ice Cream Stick
Hello! This is our worm robot
A very interesting project that you can do at home
It is very suitable for your small children
Let's see how it works. very easy
If you like this worm,Please subscribe to my Youtube channel to help me. Thanks very much
Let's make it !
⚡ Sorry everyone, but this tutorial may not be detailed. You can see the specific instructions by the video I posted above
Step 1: Prepare
Prepare 4 ice cream sticks and a rubber band
Make two holes at the ends of the ice cream stick (Second photo)
Step 2: Tick
Mark 2 points with a distance of 3cm
Step 3: Prepare Two Smaller Ice Cream Sticks
Prepare two smaller ice cream sticks and cut off the ends
It has a gap of 10.5cm ( Second photo)
Step 4: Fasten 2 Small Popsicles Onto the Big Popsicle Stick
Fasten 2 small popsicles onto the big popsicle stick
Continue with the other one, but this time only one small popsicle stick
Use a bamboo toothpick to connect the two ice cream sticks together
Step 5: Make a Hole
Make a big hole and a small hole in the bottle cap
Large holes used to attach the motor.
Small hole used to attach the moving axis.
Step 6: 4 Bottle Caps Remaining
4 bottle caps remaining. Make a small hole on it
Step 7: Attach a Gear to the Toothpick for Braking
Attach a gear to the toothpick for braking
To continue, attach the bottle cap to the toothpick to create the wheel
Make two front wheels and two rear wheels and glue it with hot glue
Step 8: Make a Small Hole to Place the Motor
Make a small hole to place the motor
Step 9: Use a Ice Cream Stick
Use a ice cream stick with 2 holes at the ends to connect the front and the back of the robot (length is 10.5cm)
Step 10: Create a Hole
Create a hole as photo
This hole allows the toothpick to penetrate and fasten the spindle
Step 11: Attach the Rotating Shaft
Attach the rotating shaft
Note that use 502 super glue to fasten each stage
Done this part. means you have already completed half the work
Step 12: Fully Prepared
Use switch, 9v battery và battery connector
Conduct electrical connection and attach to the robot
Step 13: See It in Action
hmmm. Looks like it didn't move
You can watch the video I have above to see how it works (starting from minute 04:02 - 04:09)
Step 14: Make It Move
Use a plastic sheet from the water bottle shell
And cut as shown
Then, attach it to the robot
Attention! The right arrow part touches the gear
Step 15: Cut Into Two Ice Cream Sticks
Cut into two ice cream sticks
Attach the two halves of the popsicle stick together
And put it into the robot
Do the same for both sides
Step 16: Decorate
And finally. Please decorate according to your preferences
