Introduction: Anet A8 Vanilla
Hi, this is my first instructable, i hope you find it useful.
Well, i recently bought an Anet A8 3d printer, but even with all the stuff there is outhere i had some trouble building it, so i want you to give you some tips to make the build easier, let's get started.
______________________________________________________________________________________________
Hola, bienvenido a mi primer instructable, espero que te sea útil.
Hace poco me compre la impresora 3d Anet A8 y tuve algunos problemas montándola, a pesar de toda la información que hay en internet, así que quiero ayudarte a evitar ciertos errores para que tu montaje sea más fácil.
Step 1: Check Hardware | Comprobar La Electrónica
This step is quite simple:
- Connect the power supply (check your what voltage you use, mine is 220V) and adjust it until you get the 12V in the output. (Multimeter in DCV)
- Put the multimeter in continuity and check the motors, heatbed, extruder, cables and fans.
- Wire the mainboard and the lcd together and then to the power supply (watch polarity) and check if it boots.
- Put everything back to the box and continue to the next step.
Point 1: This tests are made to PREVENT that you have to disassemble the printer after plug the power supply and realise that something is dead, needing to send it back to the seller.
Point 2: The part of continuity tests is beacause you don't need to wire everything to the main board, if the multimeter make noise, the part is OK.
_______________________________________________________________________________________________
La secuencia en este paso es bastante sencilla:
- Cablea la fuente como se ve en las imagenes (comprueba que tensión de entrada usas, la mía es 220V) y ajusta la salida hasta que estes lo más próximo a 12V que puedas. (Multímetro en corriente continua DCV).
- Después de eso comprueba la continuidad de motores, cama caliente, extrusor y ventiladores.
- Cablea la placa principal y el lcd, alimenta la placa (cuidado con la polaridad) y comprueba que enciende y hace la secuencia de inicio.
- Guarda toda la electrónica en la caja y pasa al siguiente paso.
Dato 1: hacer estas comprobaciones ANTES de montar la impresora te asegura de que no vas a trabajar en el montaje en vano si luego tienes que desmontarla porque algún componente viene estropeado y tienes que mandarla de vuelta al vendedor.
Dato 2: Comprobar la continuidad en todos los elementos antes mencionados es por simple comodidad, va a dar el mismo resultado que si los cableas a la placa principal, si el multímetro pita, funcionará.
Step 2: Build the Frame | Montar El Marco De La Impresora
The first thing we have to do when we start the assemble is ignore completely the instructions that come in the microSD and search a good youtube guide, these are the ones i used:
Some nuts will be in a hard to reach position, i recomend you to use the pliers to hold it until you secure it with the screws.
When you assemble the y-axis motor and switch, mount only the motor, you want to get the minimun amount of cables getting in the way, and believe me this is MANDATORY if you don't want to screw someting.
En nuestro ensamblaje el primer paso será ignorar el manual incluido en la tarjeta microSD, es más no conectéis la tarjeta aún. En el enlace de arriba está el video que he utilizado para orientarme durante el montaje.
Para las tuercas que estén en una posición difícil de alcanzar es mejor utilizar los alicates incluidos en el kit hasta que hayas puesto el tornillo en su posición.
Cuando vayas a montar el soporte del motor y final de carrera del eje y monta solo el motor, esto se debe a que los cables solo serán un engorro a lo largo del montaje y puedes romper algo, así que cuantos menos cables MEJOR.
Step 3: Y-Axis | Eje-y
The y-axis is really easy to assemble, you just need to follow the video and read my two convenient advice:
- Use lock nuts in one end of the rods to secure that position and achieve an easiest adjust of the smooth rods.
- Before assemble the heatbed suport change the position of the central piece, and screw it underneath the bearing conectors (or flip the whole piece 180º). This is made to guarant you will get the correct tension in the timing belt and reduce the risk of losing steps.
El montaje del eje y es el más sencillo de todos, solo hay que seguir el vídeo y estos dos consejos:
- Usa tuercas de freno en uno de los finales de las varillas roscadas para que solo tengas que ajustar un lado del eje y que las varillas lisas entren en los huecos hasta tocar las tapas.
- Antes de montar el soporte de la cama caliente cambia la posición de la pieza central atornillandola por debajo de los conectores de los rodamientos (o gira la pieza completa 180º). Esto te ayudará a tensar correctamente la correa del eje y ayudará a evitar que el motor se salte algún paso.
Step 4: Z-Axis | Eje-z
This axis is a bit more delicate, so you will need to be careful and follow this steps:
- Assemble the two motor mounts and then put the motors inside.
- Fix them to the frame and start with the screw in the side of the bed. Why? Because it's the most troublesome nut you have to fix in place, and you have two of them.
- lose the screws of the flexible coupling of the motor' shaft and extract it.
- Insert the smooth rod on the top pice of the frame and slide it down, get it inside the bearing and to the bottom. Then screw the cap in the top piece of the frame
- Do the same with the threaded rod, pass it through the screw in the x-axis support and insert it in the coupling, tighten the screws, and insert it in the motor shaft, make sure one of the screws face the flat part of the shaft, and tighten the screws.
- Repeat in the other side.
El montaje de este eje es más delicado así que es mejor que sigas estos pasos con cuidado:
- Monta los dos soportes de los motores y los motores a ellos.
- Móntalos en el marco empezando por los tornillos que están pegados a las varillas roscadas del eje-y, son los que más te van a costar y cuanto antes te los quites de encima mejor.
- Afloja los tornillos (sin sacarlos) de los acoples flexibles.
- Pasa la varilla lisa por la pieza superior del marco, mételo por el rodamiento del soporte del eje-x y luego hasta el fondo soporte del motor, y atornilla la tapa en la pieza superior del marco.
- Saca del eje del motor el acople flexible y pasa la varilla roscada por el hueco de la pieza superior, pásalo por la tuerca del soporte del eje-x, metelo en el acople, aprieta los tornillos y vuelve a colocar el acople en el eje del motor; asegurándote de que uno de los tornillos mira a la parte plana del eje.
- Repite los pasos en el otro lado del eje.
Step 5: X-axis | Eje-x
This is the last step in axis assembling, it will only left extruder an wiring.
- Insert the smooth rods in the holes of the right axis support (i recommend do it this with the supports in the top of the axis, in this way you won't need to worry for axis' alignment), AND before insert in the other axis support get the bearings in the rods.
- Make a loop with the timing belt and insert it in the motor support, once you've done this, put the motor in place trying to get the pulley inside the loop, and then, pass it around the other side of the axis.
- Screw the extruder support to the bearings.
- Make loops with the belt, tight and secure it in the screws shown in the photos.
- Screw the endstop in place and you're done.
Este paso es el último montando ejes, ya solo queda el extrusor y el cableado.
- Insterta las varillas lisas por el soporte derecho del eje (te recomiendo que subas los soportes hasta la parte superior del arco, para evitar problemas de alineacion), Y antes de meterlo en el soporte izquierdo pon los rodamientos en el eje.
- Haz un bucle con la correa dentada, mételo por el lateral del soporte del motor, una vez hecho mete el motor en el soporte tratando de que la polea entre dentro del bucle, y atornilla el motor al soporte.
- Atornilla el soporte del extrusor a los rodamientos.
- Haz dos bucles con la correa, tensala y asegúrala en los tornillos del soporte del extrusor como se ve en la foto.
- Atornilla el final de carrera en su posición.
Step 6: Extruder | Extrusor
This step is quite simple, the only thing you need to do is mount the extruder heatsink and fan, screw the unit the support and then screw the blower and you finished.
Este paso es simple, solo necesitas atornillar el disipador y el ventilador al extrusor, el extrusor a su soporte y el ventilador de la pieza al soporte y listo.
Step 7: Wiring | Cableado
This is the last step in the 3d printer assembly.
You have to be organized during this process, or you could make a wire mess. Anyway, the first thing to do, screw the lcd controller, the main board and the power suplly to the frame.
I recommend you to wire the power suplly before secure it to the frame, it's easier.
The next thing is wiring the z-axis motors, it's a bit tricky, but there are only two.
Once all said before is done it is only left the lcd, the x and y-axis motor, the heatbed, and the extruder motor.
Now we have 3 mazes of cables i recommed you to use zip ties if the helicoidal warp is too big. When every cable is tied, pass through the holes that lead to the main board and connect them. Once you're done with that, use the helicoidal warp and check everything can keep the movement of the axis without tensión or getting in the middle.
Congratulations! You've assembled your own Anet A8 vanilla.
Este es el último paso del montaje de la impresora 3d.
Tienes que ser organizado en este proceso o puedes acabar con un buen montón de cables liados. Lo primero es atornillar la pantalla lcd, la placa principal y la fuente de alimentación a la estructura.
Te recomiendo que primero cablees la fuente de alimentación, te resultará más cómodo.
Lo siguiente es cablear los motores del eje-z, requiere de un poco de habilidad, pero solo son dos.
Cuando llegues a este punto lo que te quedará es el cable del lcd, los motores de los ejes x e y, del extrusor y la cama caliente.
Ahora mismo ya tienes todos los cables necesarios, deberías organizarlos en mazos, y utilizar presillas si ves que la cinta helicoidal es demasiado grande para los cables. Cuando ya tengas los mazos hechos pasalos por los huecos del marco de la impresora hasta llegar a placa principal, conéctalos y comprueba que ninguno se queda tirante o se mete en medio del movimiento de los ejes.
¡Enhorabuena! Acabas de montar tu impresora Anet A8 original.
