Introduction: App- Controlled Robot
This is a robot kit this I bought in Korea for 100+ Dollars, but is worth only 75.99 when you save. This is cool and could be used to teach people about wires (The Kit Comes With Them) and basic programming and controlling. If you want to buy it too, here is the link https://www.amazon.com/JIMU-ROBOT-Competitive-Series-Champbot/dp/B07NVG2YG7. If you want to control you need to have an app to control it in. The app is called jimu. You can also make different things with different kits. For example you can make 2 types of robot and a car with the cosmos kit, a dragon with the firebot kit, a robot that can do many things with the mebot 2.0 kit, and much more. And for this kit, you can make a champbot (first into pic), basketball bot (second into pic), and a scorebot (third into pic. The claw arm on the front of the champbot grabs the ball and puts it onto the This stick out on the top and you can fling the ball. The 2 things on the basketbot push and lift the ball into the same place as the champbot’s and flings it the same way. The score bot is a bit different, the top platform can hold 3 balls and the claw arm lifts up ball i to the platform and then you can fling all 3 balls backwards.
Step 1: Creator0479 Out!
Thank you all for watching and have a wonderful day.
