Introduction: Arduino Alarm Clock Project
About: At Vilros, our mission is to supply a challenge that is fun, useful and rewarding. Whether you are a DIY novice or pro, enjoy the journey of computer building with us!
In this project, we will use the Arduino Uno to control an LCD screen to show the current time and time that an alarm is set for. We will use buttons to set each time.
Materials:
Step 1: Hookup Instructions
1. Connect a jumper wire from the 5V pin on the Arduino to one of the + rails on the breadboard.
Step 2:
2. Connect a jumper wire from the GND pin on the Arduino to the - rail next to the + rail you chose on the breadboard.
Step 3:
3. Connect the LCD screen to power, ground, and the TX pin (pin 1).
Step 4:
4. Place 7 buttons on the breadboard with the legs across the gap in the breadboard.
Step 5:
5. Place 10 kohm resistors from the - rail with the GND pin connected to it to the bottom left pins of the buttons.
Step 6:
6. Place jumper wires between the bottom right pin of the buttons and the 5V rail on your breadboard.
Step 7:
7. Place jumper wires between pins 6, then 8-13, and the pin on the button that the resistor is connected to.
Step 8:
8. Next, place your Piezo speaker on the breadboard and connect pin 7 to the power pin, then a 100 ohm resistor to ground.
Step 9: Programming Instructions
1. Overview: This project will ask the user to set the current time on initial power on the display the current time and the time the alarm is set for. The buttons connected above will be used to set each time. From left to right, they are set current hour, set current minute, set current AM or PM, set alarm hour, set alarm minute, set alarm AM or PM. The last button is used to silence the alarm when it’s sounding.
Step 10:
2. The first thing we need to do is initialize our variable we’re going to use.
// Initialize variables to be used
int hour = 0; // Hour for current time int minute = 0; //
Minute for current time int second = 0; // Second for current time
int hour_a = 0; int // Hour for alarm time
minute_a = 0; // Minute for alarm time
bool am_pm = false; // AM/PM toggle flag. False is AM, True is PM
bool am_pm_a = false; // AM/PM toggle flag for alarm. False is AM, True is PM
int set_hr = 13; // Use pin 13 to set hour
int set_min = 12; // Use pin 12 to set minute int
set_am_pm = 11; // Use pin 11 to set am/pm
int set_hr_a = 10; // Use pin 10 to set hour for alarm int set_min_a = 9; // Use pin 9 to set minute for alarm int set_am_pm_a = 8; // Use pin 8 to set am/pm for alarm
int speaker = 7; // Pin to use for speaker
int quiet = 6; // Pin to stop the speaker
bool alarm = false; // Flag to toggle to keep alarming
bool quieted = false; // Flag showing quiet hasn't been pressed
int cur_time = 0; // Variable for current time
int etime = 0; // Variable for elapsed time
Step 11:
3. Next, we need to set up the LCD screen and tell the user to set the current time. Since this only needs to be done once, we’ll do it in the setup routine.
void setup() {
// Set up LCD screen
Serial.begin(9600); // Initialize Serial at 9600 baud
Serial.write(17); // Turn on the back light
Serial.write(24); // Turn the display on, with cursor and no blink
Serial.write(12); // Clear the screen
Serial.write(128); // Move cursor to top left corner
// Set pinModes pinMode(set_hr,
INPUT); pinMode(set_min, INPUT);
pinMode(set_am_pm, INPUT);
pinMode(set_hr_a, INPUT);
pinMode(set_min_a, INPUT);
pinMode(set_am_pm_a, INPUT);
pinMode(speaker, OUTPUT);
pinMode(quiet, INPUT);
// On initial power, have user set current time. Serial.print("Set the current time"); delay(2000);
Serial.write(12);
printTimes();
cur_time = millis(); // Store the current time
Step 12:
4. Then, in the loop routine, we keep track of the time and read the button status’s to see if the user is setting either of the times.
void loop() {
// Keep Time
keepTime();
// Check to see if it's time to alarm!
if((hour == hour_a && minute == minute_a && !quieted) || alarm){tone(speaker, 2000, 500); // Output a 2000 Hz sound to the speaker for 500 ms
delay(500); // Delay 500 ms
if(!alarm){ // If alarm is off, turn it on
// If the user silences the alarm by pressing the quiet button, stop alarming if(alarm && !quieted && digitalRead(quiet)){
alarm = false;
quieted = true;
// Reset the alarm
if(!alarm && quieted && minute != minute_a){ quieted = false;
// Check to see if the set pins go high, and if so, increment the corresponding valueif(digitalRead(set_hr) && hour < 12){
hour++;
printTimes();
debounce();
else if (digitalRead(set_hr) && hour == 12){ hour = 1;
printTimes();
debounce();
else{}
if(digitalRead(set_min) && minute < 59){
minute++;
printTimes();
debounce();
else if (digitalRead(set_min) && minute == 59){ minute = 0;
printTimes();
debounce();
else{}
if(digitalRead(set_am_pm) && am_pm){
am_pm = false;
printTimes();
debounce();
else if (digitalRead(set_am_pm) && !am_pm){ am_pm = true;
printTimes();
debounce();
else{}
if(digitalRead(set_hr_a) && hour_a < 12){
hour_a++;
printTimes();
debounce();
else if (digitalRead(set_hr_a) && hour_a == 12){
hour_a = 1;
printTimes();
debounce();
else{}
if(digitalRead(set_min_a) && minute_a < 59){
minute_a++;
printTimes();
debounce();
else if (digitalRead(set_min) && minute_a == 59){
minute_a = 0;
printTimes();
debounce();
else{}
if(digitalRead(set_am_pm_a) && am_pm_a){
am_pm_a = false;
printTimes();
debounce();
else if (digitalRead(set_am_pm_a) && !am_pm_a){
am_pm_a = true;
printTimes();
debounce();
else{}
Step 13:
5. Here, you’ll notice a couple of subroutines I created - debounce() and printTimes(). Debounce() is used to make sure we only read the buttons once. Since the Arduino scans thousands of times per second, it may think the button was presses several times when you only intended for it to be read once. Debounce() will freeze the program until the button is released. printTimes() updates the LCD screen, but since that was several commands, I typed them once and then can call the subroutine any time a time value changes.
// While any of the buttons are being pressed, stay in this function then delay 250 ms.
void debounce(){
while(digitalRead(set_hr) || digitalRead(set_min) ||
digitalRead(set_am_pm) || digitalRead(set_hr_a) ||
digitalRead(set_min_a) || digitalRead(set_am_pm_a)){} delay(250);
// Prints the updated times if there are any changes
void printTimes(){
Serial.write(12);
Serial.print("Current Time:");
Serial.write(148);
if(hour < 10){
Serial.print("0");
Serial.print(hour);
Serial.print(":");
if(minute < 10){
Serial.print("0");
Serial.print(minute);
Serial.print(":");
if(second < 10){
Serial.print("0");
Serial.print(second);
if (am_pm){
Serial.print("PM");
else{
Serial.print("AM");
Serial.write(168);
Serial.print("Alarm Set for:");
Serial.write(188);
if(hour_a < 10){
Serial.print("0");
Serial.print(hour_a);
Serial.print(":");
if(minute_a < 10){
Serial.print("0");
Serial.print(minute_a);
if (am_pm_a){
Serial.print("PM");
else{
Serial.print("AM");
// Increment the time parameters void
keepTime(){
etime = millis() - cur_time;
if(etime >= 1000 && second < 59){
second++;
printTimes();
else if(etime >= 1000 && second == 59 && minute < 59){ second = 0;
minute++;
printTimes();
else if(etime >= 1000 && second == 59 && minute == 59 && hour < 12){
second = 0; minute =
0; hour++; cur_time =
millis(); printTimes();
else if(etime >= 1000 && second == 59 && minute == 59 && hour == 12){
0; hour = 1; am_pm =
!am_pm;
printTimes();
else{}
Step 14:
6. That’s it!
Compile and upload and you’re all done!
