Introduction: Arduino Controlled Led Light Show
LEDs dancing on music beats.
Step 1: Starting Up.
Roughly draw your sketch on the black background.
Paste LED strips on the outline.
LED used: 1amp/5metre , 12v, 1amp, size=25 x 25(single coloured), controllable RGB(50 x 50).
Step 2: Check the Pasted Led Strips
Check your pasted elements by providing external DC supply.
Step 3: Current Routing.
Routing of the current path for various elements by shorting them with the single strand wire by proper soldering.
Make sure positive is shorted with positive and negative with negative.
Step 4: Wiring and Relay Control Panel
Each element is provided a separate channel of the 5v arduino relay.
elements are provided with power supply by extending them through wires (swg 1/18) using 40amp smps(one for each screen)
Step 5: Hardware Ready
Assemble your screens.
Step 6: Software
Project is controlled by 3 Arduino Mega, one for each screen.
Each pin assigned to unique channel of the relay for switching operation.
LEDs are musically on the pre prepared track controlled by Vixen Software based on time delay.
