Introduction: Arduino MKR Cap Rail Mount
The new Arduino MKR series sets up a standard about form factor, function and performance for Arduino boards in the future. These new boards comes in a compact shape, with a powerful 32 bit Cortex M0 micocontroller Atmel SAM D21 and a charger function for LiPo accumulators. Furthermore Arduino offers in this series different types of MKR modules for different IoT wireless technologies. Besides the base model Arduino MKR Zero some further types with WiFi, WAN or GSM support are available.
I want to show you in this instructable - how to mount any board of the Arduino MKR series in a cabinet. This can be very useful for many professional applications like door access systems, smarthomes etc.
Step 1: Tools & Materials
Materials:
Tools:
  • soldering iron with small tipside
  • cutting pliers
  • needle nose pliers
  • medium cross slot screw driver
Step 2: Prepare the Terminal Blocks
Find the terminal blocks, they're grey or blue and come in 2-pin and 3-pin shapes. We'll need to slide two 3-pin blocks together.
Step 3: Place and Solder Terminal Blocks
We've to put the blocks into the proto plate. Make sure you place them so that the openends are facing out as shown
Step 4: Place and Solder the Diode
bend the pins of the diode D2. Place the diode onto the pcb and solder the pins.
Step 5: Prepare the Female Headers
Sometimes it is hard to find header with 14 pins. You can use longer female headers a cut them to 14 pins....
Step 6: Prepare the Arduino MKR Board
Plug both female headers onto the male headers of the Arduino MKR board
Step 7: Place and Solder the Arduino MKR Board
Step 8: Remove the Arduino MKR Board
Step 9: Solder the Jumper J1
beside the blue terminal block is a soldering jumper. You have to solder a bridge on this jumper if you want to connect later a external 5V power supply
Step 10: Mount the Pcb Into the Bottom Shell
Step 11: Mount the 2 Holders for the Din Rail
Please take care to mount the holder from the inner channel to the outside!
Step 12: Mount the Arduino MKR Board Again and the Top Shell
Step 13: Internal Voltage Regulator
It's possible to extend the basic kit with a voltage regulator (input voltage 9...35V; output voltage 5V)
