Introduction: Arduino & Processing - HMC5983 GY 282 Arduino & Processing COMPASS
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I make…
Hello world! Today i made a Compass for a PC or Laptop with arduino & Processing. It's very easy to build! I used the HMC5983 Magnetometer. Follow the next step for the schematic, Codes & Parts list! I did not calibrate my Magnetometer, its just a example. You should calibrate your Magnetometer in order to get the right directions.
In this instructable we use processing and arduino.
Get processing here if you don't have it . Download Processing
http://www.arduinosensors.nl -- visit our website!
Step 1: Schematic, Codes & Parts List.
Just wire it up like the Schematic, Upload the codes,Run the Processing code By pressing the play button and it should pop up on your screen.
Parts list:
  • Arduino uno.
  • HMC5983 Magnetometer (Others such as the HMC5883l work to)
Make sure you have the images for the compass from "GY_232_Compass - Processing.zip" in the right map, They should be in the same map as the Processing code. So at documents/processing/GY_232_Compass for example.
The connections are as following.
  • GND to GND arduino
  • VIN to 5V Arduino
  • SCL to SCL arduino
  • SDA to SDA arduino
Other pins are not used.
Good luck!
