Introduction: Arduino Remote Control (ARC)
In this project, we will be making a Arduino Remote Control (ARC) that decode any Infrared (IR) Remote into hex or any other format and use it to turn LED On/Off!
It’s a fairly easy project and could be done in few minutes. Here we go.
Step 1: List of Material
For this project, we will be using:
- Arduino boards (mine Arduino Uno Rev3)
- An IR Reciever
- IR 333 Transmitter
- LED
- Any Remote
Step 2: Hardware Connections
In general, the connections are very simple. Follow the instructions and images above, and you should have no problems.
Connecting IR Receiver
- The VCC pin on Arduino's 5V output
- The GND pin to Arduino's GND pin
- The Output to Arduino's digital pin 11
Connecting IR 333 Transmitter
- The VCC pin to Arduino's digital pin 3
Connecting LED
In this project I use my own custom protoshield , check it out how to make it.
Step 3: Software Programming
Upload Arduino_Remote to Arduino Uno, and Run VB_Remote from debug folder, and you should have no problem. Below is the preview of the programs.
Step 4: Enjoy!
After making sure that everything works smoothly, you can take this project into bigger project that could be controlled remotely!
Power through batteries or a plug and you’re good to go!
