Arduino + Android POV Display
Intro: Arduino + Android POV Display
POV Display is a funny and interesting way to display text in space. This is my first Instructables tutorial so IF you have any questions don't hesitate to write them in the comment section below.
STEP 1: What You Will Need
To make the POV Display I used :
- An Arduino UNO + Arduino IDE (which you can download from Here ).
- Processing Program : which you can download form Here (If using a computer for the serial communication ).
- An Android Device (If using the Android App for serial communication).
- A Bluetooth Module (almost anyone will do great just check the wiring, mine is "BTBEE PRO HC-05").
- 8 x LEDS with the color of your choice.
- 8 x 220 Ohms resistors.
- 9V DC motor .
- 9V Battery .
All
STEP 2: Circuit Diagram
STEP 3: Upload Arduino Sketch
The arduino Sketch allows you to control everything from your android device. Just Upload the sketch to the arduino and control everything from your android App.
STEP 4: Processing App (Computer Serial Communication)
For everyone that don't know what Processing is:
Processing is a programming language, development environment, and online community.. Since 2001, Processing has promoted software literacy within the visual arts and visual literacy within technology. Initially created to serve as a software sketchbook and to teach computer programming fundamentals within a visual context, Processing evolved into a development tool for professionals. Today, there are tens of thousands of students, artists, designers, researchers, and hobbyists who use Processing for learning, prototyping, and production.
I often use Processing to create applications that allow me to interface whith the Arduino through Serial Communication.
The Processing App allows you to draw any shape of your choice by clicking on the white cases and you will see it appear instantly on your POV Display Even when it is rotating at a HIGH speed.
To use the Processing App you will need to setup bluetooth on your computer.If your bluetooth is already set up you can skip this step. But you will need to change the COM Port in your Processing Sketch to the corresponding port of your bluetooth adapter.
Otherwise , If your computer doesn't have bluetooth integrated within it you will have to buy a bluetooth module or a bluetooth dongle (make sure it is compatible with your Operating System).
Then you will have to pair with the bluetooth module wired with the Arduino by entering the Bluetooth Manager on your computer and clicking on "Add a connection" or something like that then clicking on the corresponding Device.
After you complete the Pairing Step you will have to get the COM Port that is used by the Arduino Bluetooth module when connected to your computer then you open "POV_processing" and under the "Void setup()" function you replace "COM40" with your corresponding COM Port that you already got.
STEP 5: Android App (Android Device Serial Communication)
To control the POV Display I programmed an Android application using the Android Studio Development Kit. Although this app can run on almost all Android Devices (Smartphones, Tablets) but cannot run correctly on devices that have under android 4.0 installed.
This app shares the basics with the Processing App but It is more developped and has way more features.
The App allows you to control everything from your device.
I would really appreciate if you rate the App and write your feedback.
Download link: https://play.google.com/store/apps/details?id=ola.user.finalo
STEP 6: Thanks for Following !!
Thank you guys for following my project and I wish you click on the Follow Button fot more arduino projects. Also let me know in the comment section below if you have any troubles or questions you would like me to answer them.
Share a picture of your POV Display and let us know if you have some ideas to improve this Project ! ! !
40 Comments
ErwinM5 5 years ago
Kind Reagards
erwin.meyvaert@telenet.be
JhonA22 6 years ago
can you send to my email sir ...?
jhonadiguna93@gmail.com
anjalykumar121 7 years ago
plz help me to make a code....the output pins are 9,10,23,24,25,26,27,28 and also used a hall effect sensor
DavidB552 8 years ago
Hey how would I modffiy this so I can set up what it will s how at the start thewn it will only show that without need of a contol I intend to use it show so a picure of a musical note
Aswinm1 9 years ago
HEY THATS A GREAT PROJECT CAN I USE ANDROID VERSION OF 4.4.2
Khalilm 9 years ago
Absolutely yes
tomatoskins 10 years ago
I've always loved POV displays. This one turned out looking great!
Khalilm 9 years ago
Thanks . I appreciate it :D
JJJMan75 9 years ago
I started working on the display, but I have a couple questions:
*220 ohms might be too much resistance, the LEDs get dimmer along the line when wired in series. Has anyone else encountered this?
*I need an example of what functions to put under void loop for pre-coded messages; this is my first time programming the Arduino.
Khalilm 9 years ago
Hey. About the resitors : I'm using super bright LEDs so If I used resistance less than 220 Ohms it will be hard to spot the flashing LEDs from others which will make seeing the actual text or drawing harder.
And the Android app is supposed to contain a "Text Mode" feature so you can write the text of your choice using the app but i'm having some technical trouble. So you can do that manually by calling in the end of the void Loop () function printLetter() and between parentheses the number or the Capitalized Letter of your choice.
Hope this helped you :)
MayankTiwari04 9 years ago
hey khalilm can you please send the android app
device-moto g 2nd gen
android version-5.0.2 (lollipop)
Email-mayankt28@gmail.com
Khalilm 9 years ago
Hi there. The android app with be soon available in the google play store with another and better instructables page .So make sure to check my channel in the next few days ;)
okay thanks!!
Khalilm, be sure to add a potentiometer to the list of supplies. Without one, you can't control the speed of the motor
Khalilm 9 years ago
No need to change the speed of the motor
How does the Arduino know how fast it's spinning? I assumed you had to fine tune the motor speed so the letters wouldn't look stretched out or compressed.
Khalilm 9 years ago
It doesn't . I'm powering the motor with an external 9V power supply. You can vary the space between the rows of the same letter and the space between two letters by modifying in the arduino sketch the two variables "dotTime" and "letterspace". Although I wanted to use a Hall effect sensor ( you can google it for more informations) but unfortunately i didn't find it in my local electronics shop so I tried using a Reed switch but It wasn't precise enough at a high speed.
sonson 10 years ago
Khalilm 10 years ago
What's your device ?
animesh m jha 9 years ago
