Introduction: Arduino Stream Deck
I saw something from my trip to America that I thought was really cool and useful - The Stream Deck. It is basically shortcut keys for whatever app you want, great for multitasking. But the thing is it is way too expensive for me (100$) and it is not even available in my country. Still, I thought that it would be incredibly helpful to my work, so I decided to make one myself (which costed almost 10$ since the cheap Chinese Pro Micro) and share it so students and people on a budget could have one and make their life a bit simpler.
It is not in anyway even remotely as nice looking as the 100$ one but it functions just fine.
(The picture of my Deck was missing the Arduino Pro Micro since I dropped and broke it, the HC - 05 and Arduino Pro Mini was for another project so don't mind it).
Arduino Pro Micro x 1
Buttons x 12 (Arduino Pro Micro can support 12 buttons max)
PCB size that would fit your prefered number of buttons
10k Ohm resistors
Step 1: The Buttons
To make the Arduino recognize when a button is pushed, we will need to wire the buttons as such:
Button pin 1 -> 10k resistor -> GND
Button pin 2 -> VCC
Button pin 4 -> One of the Digital Pins or Analog Pins of the Arduino
Repeat until you get your desired number of buttons
My PCB is stupidly messy so its really hard to track down when an error happen, you would want it to be more organized for easier troubleshooting.
Step 2: Programming the Arduino
Programming with the Pro Micro is a bit different from the other Arduinos and would require some additional steps. I would suggest the guides that helped me program the Pro Micro:
Sparkfun's official guide:
https://www.sparkfun.com/products/12640
An Instructables guide:
https://www.instructables.com/id/Set-up-and-Instal...
After you have successfully connected your Pro MIcro to your PC and can now program it, here is the code for my Project:
<p>#define KEY_RIGHT_SHIFT 0x85<br>#define KEY_RIGHT_ALT 0x86 #define KEY_RIGHT_GUI 0x87</p><p>#define KEY_UP_ARROW 0xDA #define KEY_DOWN_ARROW 0xD9 #define KEY_LEFT_ARROW 0xD8 #define KEY_RIGHT_ARROW 0xD7 #define KEY_BACKSPACE 0xB2 #define KEY_TAB 0xB3 #define KEY_RETURN 0xB0 #define KEY_ESC 0xB1 #define KEY_INSERT 0xD1 #define KEY_DELETE 0xD4 #define KEY_PAGE_UP 0xD3 #define KEY_PAGE_DOWN 0xD6 #define KEY_HOME 0xD2 #define KEY_END 0xD5 #define KEY_CAPS_LOCK 0xC1 #define KEY_F1 0xC2 #define KEY_F2 0xC3 #define KEY_F3 0xC4 #define KEY_F4 0xC5 #define KEY_F5 0xC6 #define KEY_F6 0xC7 #define KEY_F7 0xC8 #define KEY_F8 0xC9 #define KEY_F9 0xCA #define KEY_F10 0xCB #define KEY_F11 0xCC #define KEY_F12 0xCD #define KEY_LEFT_CTRL 0x80 int buttonPin = 9; int buttonPin1 = 10; int buttonPin2 = 8; int buttonPin3 = 6; int buttonPin4 = 5; </p><p>#include <Keyboard.h></p><p><keyboard.h>void setup() { pinMode(buttonPin, INPUT); pinMode(buttonPin1, INPUT); pinMode(buttonPin2, INPUT); pinMode(buttonPin3, INPUT); pinMode(buttonPin4, INPUT);<br></keyboard.h></p><p>}</p><p>void loop() { if (digitalRead(buttonPin) == 1) //When button 1 is pressed { Keyboard.print("Print whatever phrase you want"); //</p><p> delay(1000); } if (digitalRead(buttonPin1) == 1) { Keyboard.print(""); //Whatever phrase you want } if (digitalRead(buttonPin2) == 1) //This is a shortcut for changing my keyboard's language { Keyboard.press(KEY_RIGHT_SHIFT); Keyboard.press(KEY_LEFT_CTRL); Keyboard.release(KEY_LEFT_CTRL); Keyboard.release(KEY_RIGHT_SHIFT); delay(1000); } if (digitalRead(buttonPin3) == 1) // Open App with shortcut Ctrl + Alt + t { Keyboard.press(KEY_LEFT_ALT); Keyboard.press(KEY_LEFT_CTRL); Keyboard.print('t'); Keyboard.release(KEY_LEFT_ALT); Keyboard.release(KEY_LEFT_CTRL); delay(1000); } if (digitalRead(buttonPin4) == 1) // Open App with shortcut Ctrl + Alt + p</p><p> { Keyboard.press(KEY_LEFT_ALT); Keyboard.press(KEY_LEFT_CTRL); Keyboard.print('p'); Keyboard.release(KEY_LEFT_ALT); Keyboard.release(KEY_LEFT_CTRL); delay(1000); } }
If you want your Keyboard to press "Enter" key: Keyboard.write(10); (ACSII code for Enter key is 10)
The delay after each action is to prevent the key from being spammed.
Here is the code for download:
Step 3: Creating Shortcuts Keys for Apps
Step 1: Create shortcut for the Apps you want to use
Step 2: Right click and choose "Properties"
Step 3: Click on the "Shortcut" (shown on image) and pick the key you want
For example if you choose "p" the shortcut for the App will be Ctrl + Alt + p
Now you should be good to go
//You can see in the code <p>if (digitalRead(buttonPin4) == 1) // Open App with shortcut Ctrl + Alt + p</p><p> { Keyboard.press(KEY_LEFT_ALT); Keyboard.press(KEY_LEFT_CTRL); Keyboard.print('p'); Keyboard.release(KEY_LEFT_ALT); Keyboard.release(KEY_LEFT_CTRL); delay(1000); }</p>
Step 4: Suggestions
I got all 12 keys of the Arduino Pro Micro binded to something, here is what you could do:
- Game commands or Spams (CS:GO, TF2)
- Universal Hotkeys for Windows Media Player since my keyboard does not have the Media Function Keys
Here is the guide for the plugin:
https://www.howtogeek.com/howto/19356/add-global-h...
Download Link :
http://wmpkeys.sourceforge.net/
- Auto fill passwords: If you don't want to remember password on your browser, bind it to one of the buttons (it have risks but if you don't label the keys it should be fine, use :
<p>if (digitalRead(buttonPin) == 1) //When button 1 is pressed<br> { Keyboard.print("Password"); </p><p> delay(1000);</p><p>Keyboard.write(10); // To press Enter</p><p> }</p>
Step 5: Expansions
You could try and add sensors and modules to the Pro Micro to have different ways of unlocking your PC.
Maybe an RFID reader, IR reader so that when you scan the card, or press your remote, the Pro mini could print out the password.
For example, you boot up your PC, instead of typing in your password, you scan the RFID key and the PC is unlocked.
I have been thinking about this for a while but never made it since my PCB is out of room for the scanner, but I hope you guys could make it a reality.
