Introduction: Arduino Tutorials (part 4 - 21 Tutorial Pack)
This is Arduino Tutorial Pack Part 4.
The 1st part is available here: https://www.instructables.com/id/Arduino-Tutorials-part-one-16-Tutorial-Pack/
The 2nd part is available here: https://www.instructables.com/id/Arduino-Tutorials-part-two-17-Tutorial-Pack/
The 3rd part is available here: https://www.instructables.com/id/Arduino-Tutorials-part-3-17-Tutorial-Pack/
Unlike other tutorials here I won't give any background in theory how it works. It is oriented to the result how to achieve it - to make measurements from lots of sensors and, in some cases, to accomplish various control or indications! Watch the videos and after that just adopt the code to your needs/project. Easy as that! All schematics available in video! Pin numbers in the schematics is what matters! In some cases connection pins of Arduino microcontroller and sensor are commented in Arduino code!
The content of the tutorials looks like that (just press view all steps for easier navigation):
Arduino and Fingerprint Reader
Arduino and 0.5 inch OLED LD7032, Gas Sensor MQ135
Arduino and Galvanic Skin Response (GSR) Sensor
Arduino and Dust Sensor
Arduino and Ultraviolet (UV) Sensor
Arduino and HCHO, Benzene, Toluene, Alcohol Sensor
Arduino and Infrared Temperature Sensor
Arduino and GestureR TINY
Arduino and Real Time Clock (RTC) Module
Arduino and 0.94 inch I2C 128X64 White OLED SSD1306 LCD LED Display Module
Arduino and 2 Axis Analog Joystick – Expanded
Arduino and Matrix Display, Number Display, Bar Graph Display
Arduino and RGB Control With Processing
Arduino and SW-420 Vibration Sensor
Arduino and Stepper Motor Drive Controller Shield Modules L298N and L293D
Arduino and Relay Module with Optocoupler
Arduino and Voltage-Current Measurement Sensor B43 (MAX471)
Arduino and Optical Sensor TCRT1000
Arduino Pro Micro and MARG MPU-9250 for Inertial Mouse
Arduino and Digital Gyroscope ITG3200 for Angular Velocity and Angle
Arduino and Reed Switch
Step 1: Arduino and Fingerprint Reader
Download #Arduino Code for fingerprint enrollment (*.ino file)
Download #Arduino Code to delete fingerprint (*.ino file)
Download #Fingerprint reader library (*.rar file)
Download # Processing Software from here
Download #Processing Code for Universe Destruction (*.rar (after extraction start *.pde file))
Step 2: Arduino and 0.5 Inch OLED LD7032, Gas Sensor MQ135
Download #U8glib Library for LD7032 OLED Display (*.rar file)
U8glib library can be also used for many other display modules - list provided in sample codes
Download #MQ135 Library for MQ135 Gas Sensor (*.rar file)
Download #Arduino Code for 0.5 inch OLED LD7032 and Gas Sensor MQ135 (*.ino file)
or
Upload Arduino code directly to your Microcontroller from website
Download #Arduino Code just for MQ135 Gas Sensor (*.ino file)
or
Step 3: Arduino and Galvanic Skin Response (GSR) Sensor
Download #Arduino Code (*.ino file)
or
If you want to integrate Arduino IDE into your website (as above) sign up here:codebender
Step 4: Arduino and Dust Sensor
or
Step 5: Arduino and Ultraviolet (UV) Sensor
or
Step 6: Arduino and GestureR TINY
Download #Arduino GestyreR TINY Gesture Code (*.ino file)
Download #Arduino GestyreR TINY Light Code (*.ino file)
or
Step 7: Arduino and HCHO, Benzene, Toluene, Alcohol Sensor
or
Step 8: Arduino and Infrared Temperature Sensor
or
Step 9: Arduino and 0.94 Inch I2C 128X64 White OLED SSD1306 LCD LED Display Module
Download #U8glib Library for LED Display Module (*.rar file)
or
Step 10: Arduino and Real Time Clock (RTC) Module DS3231
Download #Real Time Clock Library (*.rar file)
or
Step 11: Arduino and 2 Axis Analog Joystick – Expanded
or
Step 12: Arduino and Matrix Display, Number Display, Bar Graph Display
Download #Arduino Code for Matrix Display (*.ino file)
Download #Arduino Code for Number Display (*.ino file)
Download #Arduino Code for BarGraph Display (*.ino file)
or
Step 13: Arduino and RGB Control With Processing
Download #Processing Code (*.pde file - Processing software itself is available to downloadhere)
or
Step 14: Arduino and SW-420 Vibration Sensor
or
Step 15: Arduino and Stepper Motor Drive Controller Shield Modules L298N and L293D
or
Step 16: Arduino and Relay Module With Optocoupler
or
Step 17: Arduino and Voltage-Current Measurement Sensor B43 (MAX471)
or
Step 18: Arduino and Optical Sensor TCRT1000
or
Step 19: Arduino Pro Micro and MARG MPU-9250 for Inertial Mouse
Download #MPU-9250 Library (*.zip file)
or
Step 20: Arduino and Digital Gyroscope ITG3200 for Angular Velocity and Angle
Download #ITG3200 Library (*.zip file)
Download #Serial Oscilloscope v1.5 (*.zip file)
or
Step 21: Arduino and Reed Switch
or
