Introduction: Arduio Biometric, or Vioce Controlled Robotic Hand
Making a muscle controlled robotic hand. Using an Arduino, an EasyVR shield, or a Myoware biometric EMG sensor, and a robotic claw, or 3D printed hand.
Step 1: Parts
Arduino
EasyVR Shield https://www.sparkfun.com/products/13316
Robotic Claw https://www.sparkfun.com/products/13174
(retired claw pictured) https://www.sparkfun.com/products/retired/11524
(servo) https://www.sparkfun.com/products/10333
(alternate source for retired claw) http://www.ebay.com/itm/Manipulator-Paw-Alloy-Arm-...
(alternate source for retired claw w/ servo) https://www.aliexpress.com/item/Aluminium-Robot-Cl...
3d printed hand (optional) http://www.thingiverse.com/thing:754513
Myoware Sensor https://www.adafruit.com/products/(retired)2699 https://www.sparkfun.com/products/13723
Step 2: Wiring Sensor
MyoWare "+" to Pro Trinket 5V
MyoWare "-" to Pro Trinket GND
MyoWare "SIG" to Pro Trinket A0
Orange Servo Wire to Pro Trinket #3
Red Servo Wire to 5V
Brown Servo Wire to Ground
Step 3: EasyVR Programming
http://www.veear.eu/downloads/
Step 4: Mount Claw/hand
I used the flexy hand with the bolt attachment for the 3d printed hand, or the robotic claw from sparkfun. I made a scrap metal mount for the claw. Sorry I don't have the files for mounting the servo, but each prosthetic is so different (and my 3d printers extruder just broke). I will post the one for mine as soon as it's finished.
Step 5: Programming for Biometric Sensor
#include
Servo myservo;
// constants
const int iServoPin = 3; // servo pin number
const int iSensorPin = A3; // muscle sensor pin number
const int iMaxServoVal = 1140; // HS-7940's fully extracted claw servo position PWM value (in microseconds) const int iMinServoVal = 1800; // HS-7940's fully retracted claw servo position PWM value (in microseconds) const int iMinThreshVal = 200; // muscle sensor threshold value to begin controlled extension
const int iServoStep = 10; // controls claw extension speed - increase to speed up
const unsigned long lLockOut = 2000L; // duration to hold max threshval to toggle the lock state (in milliseconds)
// global variables
unsigned long lStartTime = 0L; // variable to store the time the timer was started
bool bStartLockTimer = false; // if true, the timer has been started; false otherwise
bool bActiveLock = false; // if true, the claws have been locked in fully extended state; unlocked otherwise.
void setup() { myservo.attach(iServoPin); // attaches the pin to the servo object
delay(10000); // 10 second delay to give you time to plug in the battery, stow it, and get clear
void loop()
// read muscle sensor value
int iSensorVal = analogRead(iSensorPin);
int iServoVal = iMinServoVal; // intialize to min value
// determine what state to put the claws in based on the sensor value
// three possible states
if(iSensorVal < iMinThreshVal)
// state 1 - below threshold - fully retract claws
else
// state 2 - above max threshold - fully extend claws
iServoVal = iMaxServoVal;
// if sensor is in state 2, start timer to trigger lLockOut
if(iServoVal == iMaxServoVal)
// if the timer hasn't been started, then start it.
if(!bStartLockTimer)
lStartTime = millis(); bStartLockTimer = true;
else
// reset timer variables
lStartTime = 0L; bStartLockTimer = false;
// check to see if the timer was started and it runs for the amount of time required to trigger lock/unlock
if(bStartLockTimer && millis()-lStartTime >= lLockOut)
// toggle lock state
bActiveLock = !bActiveLock;
// set servo value to max when locking
if(bActiveLock)
myservo.writeMicroseconds(iMaxServoVal);
else
// reset servo value to min when unlocking
myservo.writeMicroseconds(iMinServoVal);
// pause for a second to allow the user to adjust to the new setting
delay(1000);
// move the servo to the desired postion
if(bActiveLock) myservo.writeMicroseconds(iMaxServoVal);
else
myservo.writeMicroseconds(iServoVal);
// delay to not overload the ADC
delay(100);
