Auto Trash by Arduino
Intro: Auto Trash by Arduino
This instructable is so called Auto Trash, but do not overlook it, it just open the lid when you closed to it. This is a not a fancy toy, you can actually buy a factory make from warehouse store, but the price is often beyond your imagination. I made this instructable for experiment purpose, I had previously made the H-bridge motor driver (https://www.instructables.com/id/Bipolar-Stepper-Motor-Driver/) that could be useful here, I connected the driver with bipolar stepper motor to arduino broad and the supersonic transducer.
STEP 1: The Litter Bin
I choose a small litter bin, originally I wanted to install a large bin, but the motor was not powerful enough to pull up the lid. I installed a small rod extended the back side of the lid, and pull the rod with a wire connected to the motor disc or crank shaft. Actually this can be done with servo motor, I just transplanted the assembly from large bin to small bin.
STEP 2: The Code
The connection is shown here
#include <Stepper.h>
const int stepsPerRevolution = 20;
// change this to fit the number of steps per revolution // for your motor
// initialize the stepper library on pins 8 through 11: Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
void setup() {
// put your setup code here, to run once:
// set the speed at 60 rpm:
myStepper.setSpeed(60);
pinMode(7, OUTPUT);//trig
pinMode(6, INPUT);//echo
void loop() {
// put your main code here, to run repeatedly:
myStepper.step(0);
if (scan()<15) {
myStepper.step(stepsPerRevolution);
delay (1500);
myStepper.step(-stepsPerRevolution);
delay (1000);
watchdogSetup();
long scan() {
long duration;
digitalWrite(7, LOW);
delayMicroseconds(2);
digitalWrite(7, HIGH);
delayMicroseconds(10);
duration = pulseIn(6, HIGH);
return (duration/2) / 29.1;
void watchdogSetup(void){
WDTCSR |= (1<<WDCE) | (1<<WDE);
WDTCSR = (1<<WDIE) | (1<<WDW) | (0<<WDP3) | (1<<WDP2) | (1<<WDP1) | (1<<WDP0);
ISR(WDT_vect) {
// Watchdog timer interrupt.
STEP 3: A Special Feature
I noticed the bipolar motor consumed 1A current at 5V even no movement, the motor pitches are engaged, this made the motor hot without any work done, but when I reset the board the current can ceased, so I add a watchdogsetup() code to reset the board, check the end of video.
2 Comments
AshkanK1 8 years ago
nice ideas
tytower 8 years ago
The electronics needed are about as big as the bin. Not real practical at that size but if you can get them smaller and the bin bigger its a brilliant idea
