Introduction: Automatic Dog Feederrr!!
Easy, Helpful and Healthy!!!!!
Step 1: Description and Materials
Description
This is an automatic dog feeder that is timed at certain times throughout the day this helps you not to feed your dog and helps you save time and will make the dog happier and healthier since it will have its right amount of meals throughout the day.
Materials
- Arduino UNO
- Breadboard
- 11 cables
- 6 Resistors
- 1 Diode
- 1 servo motor
- 1 Ultrasonic sensor
- Push Button
Step 2: Code
You need to adjust the time you want to feed the dog in the code I put a short amount of time so I can test it You cant decide at what time you want the feeder to feed your dog.
Step 3: Model
This is a model without the box and the food as you can see it has the sensor to detect when the doc is close this will activate the RGB light. So you know when the dog is close you can set up different colors for it to turn on and this will make you notice when he is hungry or not since the dog wants food.
Step 4: Conclusion
This feeder had pros and cons you need long cables to make it work and it depends on the size of dog you have if it is a small one you will require fewer cables and make a small feeder and if it is a big one you will require more cables to make it reach around the container and box. This will make your dog happier and healthier and will have a good overall effect on your dog.
