Introduction: Automatic Water Level Controller for 2 Pumps and 1 Rooftop Tank and 1 Underground Tank
I made this project for the building, where I live. It was a tedious and annoying job to turn the motor on everyday and stop in time. So after a lot of research and designing on the internet. I came up with this idea and made it. It took me more than 2 months to perfect it.
We have 2 water pumps which fill the same roof top tank.
- Submersible 1.5 HP Pump
- Jet pump in underground tank.
I've used float switches in both the tanks as shown in the photo.
Parts list :
- Float switches - 4 pcs
- Atmega328 with Bootloader- 1 pc
- 30amps Relays - 3 pcs
- 5amps Relays - 4 pcs
- 10k ohms resistors for switch input to pulldown - 5 pcs
- ULN2003 - 1 pc (to give 12v power to the relays)
- 12v 1amp power adapter
- LM7805 & 1000uf Capacitors (to regulate 5v for the atmega328)
- Screw Terminal Connectors
- Some LEDS
- Lots of wires, soldering Iron and Lead solder.
- Arduino UNO to program the atmega328
- Diodes (to make a reverse protection).
- Good quality 3 core wires are used for roof top tank sensors and underground tank sensors.
Step 1: Solder the Circuit As Shown in the Circuit Diagram.
Circuit diagram shows the wiring of items.
Step 2: Program the Atmega328 Using Arduino Ide and Arduino Uno
- Use a 28 pin mcu holder on the PCB so that Atmega328 MCU can be removed again and again for changes in program.
- Click here to know how to program atmega328 without oscillator.
- If the 8 mhz bootloader is done, then put the atmega328 on the arduino uno and program it directly using USB.
- The file attached here has the arduino code to be used. You can change the pin numbers as per your requirements in the configuration section.
The Program is :
///////////Configuration Section//////////
int r1 = 11; // Atmega328 pin 17 // Relay 1 Pin Submersible Motor Main
int r2 = 12; // Atmega328 pin 18 // Relay 2 Pin Submersible Motor Boost
int r3 = 13; // Atmega328 pin 19 // Relay 3 Pin Monoblock Motor or Ground Tank Motor
int enb = 0; // Atmega328 pin 2 // Enable Switch Power to read the values
int led = 9; // Atmega328 pin 15 // Loop LED
int LED1 = 5; // Atmega328 pin 11 // S1 LED
int LED2 = 6; // Atmega328 pin 12 // S2 LED
int LED3 = 7; // Atmega328 pin 13 // S3 LED
int LED4 = 8; // Atmega328 pin 14 // S4 LED
int s1 = 4; // Atmega328 pin 6 // Switch 1 Pin (Upper level of Overhead Tank)
int s2 = 3; // Atmega328 pin 5 // Switch 2 Pin (Lower level of Overhead Tank)
int s3 = 10; // Atmega328 pin 16 // Switch 3 Pin (Upper level of Ground Tank)
int s4 = 1; // Atmega328 pin 3 // Switch 4 Pin (Lower level of Ground Tank)
int in = 2; // Atmega328 pin 4 // Inturrupt Pin, to stop the delay function.
int b1; // Holds value of Switch 1 int b2; // Holds value of Switch 2
int b3; // Holds value of Switch 3 int b4; // Holds value of Switch 4
int a=0; // Stops execution of codes again & again
long int i=0; // Loop Counter
int R2Delay= 1800; // Delay to keep R2(Boost for Submersible) On
int SwDelay = 500; // Delay between switching Motors
long int loops = 1; // Number of loops to wait
////////////Configuration END////////////////////////////////////////////////////////
////////////////Program Bigin////////////////////////////////////////////////////////
void setup()
{ pinMode(r1, OUTPUT);
digitalWrite(r1, LOW);
pinMode(r2, OUTPUT);
digitalWrite(r2, LOW);
pinMode(r3, OUTPUT);
digitalWrite(r3, LOW);
pinMode(enb, OUTPUT);
pinMode(led, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(s1, INPUT_PULLUP);
pinMode(s2, INPUT_PULLUP);
pinMode(s3, INPUT_PULLUP);
pinMode(s4, INPUT_PULLUP);
pinMode(in, INPUT_PULLUP);
readWaterLevel(); }
void loop()
{ digitalWrite(led, 1);
delay(200);
if(i>=loops)
readWaterLevel();
i=0; }
if((digitalRead(in) == 1))
{ readWaterLevel();
if(b1==1)
{ b2=1; } }
if((digitalRead(r1) == 1) || (digitalRead(r3) == 1))
{ loops = 500; } //Number of Loops to Wait before Reading the Switches when any Motor is ON
else { loops = 5000; } //Number of Loops to Wait before Reading the Switches when Motors are off
if((a == 0) && (b1 == 1) && (b2 == 1) && (b3 == 1)) //OverHead Tank Empty
{ Submersible();
a=1; }
else if((a == 0) && (b1 == 1) && (b2 == 1) && (b3 == 0)) //Overhead Tank Empty
{ Monoblock();
a=1; }
else if((b3 == 1) && (b4 == 1) && (digitalRead(r3) == HIGH)) /////Ground Tank gets Empty
{ digitalWrite(r3, LOW);
a=0; }
else if((a==1) && (b1 == 0) && (b2 == 0)) /////Overhead tank is Full
{ AllOff(); a=0; }
digitalWrite(led, 0);
delay(300);
i=i+1;
}////////////Loop End////////
void readWaterLevel()
{ digitalWrite(enb, 1);
delay(750);
b1 = digitalRead(s1);
b2 = digitalRead(s2);
b3 = digitalRead(s3);
b4 = digitalRead(s4);
LED_Status();
delay(50);
digitalWrite(enb, 0); }
void Submersible()
delay(SwDelay);
digitalWrite(r1, HIGH);
delay(SwDelay);
digitalWrite(r2, HIGH);
delay(R2Delay);
digitalWrite(r2, LOW); }
void Monoblock()
{ digitalWrite(r1, LOW);
delay(SwDelay);
delay(SwDelay);
digitalWrite(r3, HIGH); }
void AllOff()
delay(SwDelay);
delay(SwDelay);
delay(SwDelay); }
void LED_Status()
{ digitalWrite(LED1, b1);
digitalWrite(LED2, b2);
digitalWrite(LED3, b3);
digitalWrite(LED4, b4); }
Step 3: After the Circuit Is Finished. Place It in a Box of Your Choice.
I have used a PVC box used for electrical switches which is commonly available in electrical stores/hardware stores. You can decide the box on your own depending on how you made your project.
