Introduction: BEST JACK O LANTERN EVER !!!
I've made many jack o lanterns in my time BUT I've got to say that this one takes the cake!! And what better time than now to make such a statement !!!
Pumpkin
Covered surface to work on
Knife
Dremel
Scoop
Sharpie marker
Bowl
Paper towels
Light
Knife
Dremel
Scoop
Sharpie marker
Bowl
Paper towels
Light
Step 1: Cut Top Off Pumpkin and Trim Guts Off Bottom of the Top Piece
Step 2: Using Spoon , Scoop Out All Guts and Seeds
Step 3: Use the Sharpie Marker to Mark Your Design...
Step 4: Using the Dremel With a Drill Bit Tip, Begin Drilling Holes Along the Lines of the Design
As you drill the holes , wipe the pumpkin guts from the holes with paper towels . Continue drilling holes into the rest of the design outline until it's all drilled.
Step 5: After Drilling Holes , Be Sure All Holes Are Completely Thru the Pumpkin - Make Sure U See Light Showing Thru the Holes From the Inside
Use a bamboo kebab stick to poke thru each hole if needed
Step 6: Add Tea Light or Any Other Light You Prefer Inside the Pumpkin and Place Top Back On
I personally like the lights that have a n uto timer built in so there's no worry bout shutting it off the next morning- enjoy ur pumpkin !! HAPPY HALLOWEEN 🎃
