Introduction: Baby Proof Fireplace
We have a fireplace in our living room, which happens to be where our son likes to play. He is very active and as parents, have been worried about him hitting his head on the brick/concrete. So we decided to look at ways to cover this. Wr tried just putting pillows there, and although that would work, it was not the best solution. After looking online, we decided to see if we can make a bench that will work. We needed it to be sturdy enough to sit on, soft enough that if our son hit his head on it it would not hurt, and also needs to be able to be removed for when we use the fireplace.
Step 1: Gather Materials
For this we used:
Various pieces of pine wood
Drill
Floor screws
Wood Glue
Foam Flooring
Adhesive Spray
Seat Stuffing
Old Sheet
Stable Gun
Stables
Heavy Objects
Circular Saw
Jigsaw
Scissors / Exacto Knife
Step 2: Measure and Cut
Cut the following (all to fit around the fireplace - measurements will be different for each fireplace and need)
1 long flat piece to be the top (where you sit)
1 long flat piece to be the front
2 short pieces for the sides
2 pieces of wood to support the seat between the mantle and seat
Step 3: Assemble Seat
Started on one side and began screwing in the boards to make a box. Screwed the front piece to the top piece and the supporting side pieces.
Step 4: Trim Seat to Fit
Using a jigsaw and circular saw, we cut out the fireplace insert so that the bench will sit flush against the brick
Step 5: Add Seat Support
Using a couple of boards and a few screws, placed a couple pieces of wood to support the seat. This will rest on the fireplace
Step 6: Add Floor Foam
Using woodglue, we placed foam flooring to the bench to help create a base for where the stuffing will sit for the seat. Using heavy objects to place on the floor to help make it stick
Step 7: Trim Flooring
Using Scissors or an exacto knife, begin trimming the flooring
Step 8: Spray Adhesive and Place Stuffing
Using the spray adhesive, we sprayed the whole bench (Do this step outside as the spray stinks and sticks to everything!)
We placed the stuffing over the bench and applied pressure to make it stick.
Using scissors, we trimmed the extra.
Step 9: Put Cover on and Staple
After the stuffing is on and all trimmed, it is time to put the cover on.
Using a sheet of your choice (we used an old bed sheet) start at one corner and pull it tight. When creases are gone, staple the sheet on the bottom or inside of the box (do not staple where it will be seen)
Continue to pull and staple the sheet until the whole box is covered.
Once all stapled, use scissors to trim the sheet and remove an extra.
Staple any other loose sections or hanging pieces
Step 10: Check Placement and Add Pillows
Once done, place the bench back to check the fit. Once happy with the fit, add some pillows for decorations.
