Introduction: Ball Cage
Learn to make a ball cage from a standard wood shelves and a few other materials. A simple Home Improvement project to keep all those sports balls in their place.
Find another Unusual Use for those spare conduit straps you have leftover from your last electrical job.
This is a simple modification to make a secure ball cage with a few materials on existing shelves.
Look at this is a modification to my Garage Shelves Instructable. Prior to this Instructable my intentions were to make some corner shelves in my garage. Well, shelves are simple enough until you decide what you are going to store on the shelves.
After attempting to store my kids inventory off balls, I discovered they were rolling off the shelf and onto the floor and into the driveway. What a mess! Gotta fix that problem.
Well, this Instructable is another Home Improvement lesson on how to keep the balls on the shelf where they belong! You can do this with any set of wood shelves.
Step 1: Tools and Materials
Since I always have a surplus of materials after initial projects, there was no additional cost out of pocket for this project. All materials I already had on hand laying around the garage.
The amount of each item will be based on your shelf sizes.
Materials are based on my shelves that were 56 inches wide.
Materials
- Existing Wood Shelves
- 18- 1/2 inch conduit straps
- 18- 1 5/8 inch deck screws
- Approximately 40 feet of 3/8 inch nylon utility rope
Tools
- Measuring tape
- Marking pencil
- Power Drill
- Utility Knife
- Phillips Screw Bit
- Hammer
Step 2: Measure
With a tape measure in the center of the top and bottom of the rails, I made drill marks every 7 inches. This will give me 9 anchor points for each the top and bottom of the rails.
Step 3: Mount Anchors
With the drill gun I mounted a conduit strap at each of the anchor points for the top rail. I then used the level to carry the mark down to the lower rail. This saved time on measuring a second time.
Step 4: Lace Rope
Next, lace about 20 foot of rope loosely in a zigzag pattern between top and bottom rails.
Step 5: Knot - Cut - Singe
Pretty simple here.
After lacing through the first rope, tie off one end into a knot.
- Tie it off into a simple not.
- Cut the excess.
- Singe the end with a lighter or match to keep it from fraying.
Step 6: Pull Tight
Pull the rope tight through each of the anchors then..
Knot - Cut - Singe
Rope 1 is Done!
Step 7: Repeat
Repeat the process for the second rope to complete the process.
- Lace it through the anchors.
- Tie off one end and cut and singe.
- Pull tight through anchors.
- Tie, Cut, and Singe!
Step 8: Tight Rope
At this point you are done.
Rope should be tight with no slack
Step 9: Tap the Straps
Give each of the straps a couple taps with a hammer to dig the end into the wood for added strength in the anchoring.
Step 10: Place the Balls
At this point, push all the balls through the ropes to secure them into the shelf.
No more balls rolling off the shelf.
Overall, a simple DIY Home Improvement Project!
Another Instructable by the DiyWaterDog.
Follow Me on Twitter, Pinterest,Instagram, Tumblr
