Introduction: Ball and Cup Game
Step 1: Supplies
A 8 inch stick that has at least a 1.5 inch diameter
A 2 foot piece of string
A drill
A 1 inch drill bit and a 1/8 inch drill bit
A sharp knife
A 1 inch by 1 inch piece of a stick or a 3/4 inch ball
A drill
A sharp knife
Step 2:
The first thing you have to do is to carve the handle with the knife. Carve it enough so that the bark is off and the handle is smooth.
Step 3:
Next you will be using the 1 inch drill bit and drill a hole in the top of the stick about 1 inch down.
Step 4:
After that use the 1/8 size drill bit and drill a hole just above where you carved your handle.
Step 5:
Last put the string through the 1/8 inch hole and tie a big enough not where it won't go through. Then drill a 1/8 inch hole through the ball or 3/4 inch by 3/4 inch stick and put the string through, then tie a not.
Step 6:
Then your done!!!
