Introduction: Ballistics Gel
This is a cheap and easy way to make ballistics gel easily
The Mythbusters use this stuff all the time
I got this idea from mythbusters and i see them use it all the time on the show so I wanted to make some
Step 1: What You Need
- Unflavored gelitan packets
- Measuring cups
- Measuring bowl
- Spoon
- Tupperware container
- Measuring cups
- Measuring bowl
- Spoon
Step 2: Step 1
measure out 2 cups of warm water
you need to add 2 gelatin packets for every cup of water
Step 3: Step 2
Slowly mix in the 4 packets of gelatin with the 2 cups of water
make sure you are stirring the water as you are adding the gelatin
if you don't the gelatin will clump up
Step 4: Step 3
Add your mix into your Tupperware container then
freeze it for a half an hour
let it sit in room temp for 10 minutes
then refrigerate it for 30 minutes
then freeze it again for 12 - 14 hours
Step 5: Finished
It should look like this when you're done
I love to make this stuff I test my knives and airsoft guns on this
If you liked this project follow me on instructables to get notice of when I come out wit my new projects
Thanks
Please check out my other instructables
Thanks
