Introduction: Barrel Chair
Ever wondered what to do with your old whiskey barrels? Maybe not, but if you're lucky enough to stumble upon one, it's a golden opportunity to accomplish some unique woodworking. This project isn't fast, and it isn't easy, but with some serious sweat and outdoor work you'll have an absolutely rugged chair to sit back in.
- One Barrel
- Two 48"Dowel Rods
- Two 3/8" dia. bolt
- Twelve 1/4" dia. bolt
- Four Screws
- Wood Glue
- Spar urethane
- Clear Gloss Enamel
- Four Rubber Bumpers
Tools
- Table Saw
- Hand Saw
- Drill Press
- Hand Drill
- Hammer
- Chisel
- Philips Screw Driver
- Wrench
- Paint Brush
- 2 Bar Clamps
- Sander
- Bench Vice
- Square
- Tape Measure
- Wire Brush
Step 1: A Few Things to Know
There are 3 irregularities in a barrel stave
- The inner charred face is narrower than the outer face. As a result, its sides are slightly beveled out.
- The middle of the barrel stave is wider than the far sides.
- The entire barrel stave has a curve radius
Step 2: Take Apart the Barrel
- Gently turn the barrel on its side
- Tap the steel bands off with a hammer
- Remove steel rivets from the bands using a drill press, hammer, and chisel
Step 3: Choose the Right Parts
8 barrel staves.
- 4 for the legs - approx. 1.75" wide.
- 2 for the cross pieces - approx. 1.5" wide
- 2 for the back rest - approx. 1.5" wide
1 wood end cap
3 steel bands
- 2 for the back rest - Use the end bands as these have a slight bevel
- 1 for the leg braces - Use a middle band as they are the most strait
Important:
- Staves of similar thickness form better joints
Step 4: Build the Legs
The legs are formed using 2 lap joints. Each lap joint is reinforced with 2 wood dowels.
- Trim off the top 2" of the stave at a 50 deg. angle
- Cut parallel saw kerfs for 2". The depth of each kerf should be 1/2 the thickness of the stave
- Chisel off the cut wood to reveal the lap
- With the laps temporarily clamped together drill 2 holes for the dowels
- Apply glue and hammer in the dowels
Important:
- All cuts must be made at the same angle
- Both legs must be the same height
- Chisel the laps as flat as possible
Step 5: Build the Cross Pieces
2 cross pieces are cut and joined to the legs via 4 mortise and tenon joints.
- Trim both ends of each stave to form 22" long cross pieces
- Cut parallel saw kerfs for 2" on each side of each cross piece. Choose a depth that suits you, but keep it consistent.
- Chisel off the wood on each side to reveal a tenon
- Outline the size of each mortise on each chair leg. The front cross piece should be approx. 1" higher than the back
- Drill as many holes as possible inside each outline.
- Chisel out the outline to form the mortise
- Drill a hole in the side of the tenon
- Saw a kerf from the tip of the tenon to the drilled hole
- Hammer the joints in place with glue
- Hammer a wedge into the saw kerf
Important:
- Make sure you tenon is flat
- The joint cannot be loose. If it is loose, the wood will split when you hammer in the wedge
- With the joint in place, the legs should be 18" apart from eachother
Step 6: Cut the Seat
- Using a table saw cut your barrel top into 5 strips approx. 3" wide.
- Trim the front of each piece so that the seat is 17"-18" at its longest point
Step 7: Build the Back Rest
The backrest is made by joining barrel staves to the seat via mortise and tenon joints.
- Cut the 2 barrel staves in half for a total of 4 pieces
- Trim each piece to be 16" in length
- Using a table saw trim parallel saw kerfs for 2" . The kerfs should be cut at a 15 deg. angle
- Chisel off the cut ends to reveal the tenon
- Outline the front of each mortise on each seat slat
- Drill as many holes inside the outline as possible. Orient the drill to 15 deg.
- Chisel out the drilled outline to reveal a mortise
- Saw a kerf from the tip of the tenon to the hole
- Hammer the wedge into the saw kerf
Important:
- The back rest sits at a 15 deg. angle, this effects the angle at which the mortise and tenon are cut.
- Because these kerfs were cut on the flat end, I can use a table saw.
Step 8: Install the Seat
- Drill 4 holes in each slat. 2 holes in the front, 2 in the back
- Apply wood glue
- Hammer one dowel into each hole
Important:
- Each hole in the slat must line up perfectly with the corresponding hole in the cross piece
- To keep the slat from sliding, have someone hold it down while you drill
Step 9: Trim the Wood
Trim all joints to preference.
Step 10: Fit the Steel Back Rests
- Holding the steel bands up to the chair mark where holes will be drilled in the wood
- Drill the holes in the wood
- Loosely bolt the steel in place, bend if necessary
Step 11: Fit the Steel Leg Braces
- Cut four 9" pieces from the strait steel band
- Hammer each band into a quarter-circle
- Drill a hole each end of every band
- Line the band up in each leg, marking where a hole should be drilled in the wood
- Drill one hole in each leg
Step 12: Brush the Steel
Remove all rust with a wire brush
Step 13: Sand and Paint the Wood
- Sand the wood
- Apply spar urethane
Step 14: Paint the Steel
Coat the steel in a gloss enamel to prevent rust
Step 15: Assemble
- Put the bolts in finger-tight
- Pre-drill 4 holes in the cross pieces, one for each wood screw
- Screw in the wood screws
- Tighten the bolts
- Hand screw rubber bumpers to the feet
Step 16: Conclusion
The chair turned out a little heavy, but definitely sturdy. It is comfortable, and without armrests is best suited as a table chair.
