Introduction: Basing Miniatures
Things you will need:
- CA glue (Super Glue/Crazy Glue)
- PVA Glue
- Sand
- Small Stones
- Water
- Paints
- Brushes for paint
You can also prep your bases by lightly sanding the top of them or just scratching them with a knife, this is called keying and helps the glues stick to the plastic bases.
How I got the sand and stones I use: https://www.instructables.com/Cleaning-and-Drying...
Step 1:
Using CA glue on the rocks then PVA glue everywhere else
Step 2:
Dipping into sand and shaking off the excess
Step 3:
Mixing 50/50 PVA with water then a few drops of paint and saturate using brush
Step 4:
Let dry
Step 5:
Use 50/50 water with paint and saturate with brush
Step 6:
Let dry
Step 7:
Dry-brush highlights ontop
Step 8:
Now you can base all your minis quickly and pretty easily for a stong long lasting effect
