Introduction: Beebeecraft Beginners Project – Making a Blue Winding Bracelet With Glass Beads
This tutorial is for those who want to make a bracelet with simple materials. Blue beads and golden wire match very well. Never tried before? Take it easy. You can make it by following the steps below.
This is the appearance of the bracelet we are going to learn today. From the photo we can know that there is no complicated procedure. We can make the bracelet by repeating the same step. Are you ready for it?
Step 1: Supplies Preparation
Materials and tools needed:
4x3mm Faceted Blue Glass Beads
13x7mm Golden Ribbon Ends
14x8mm Golden Lobster Claw Clasp
6mm Golden Jump Rings
0.8mm Golden Aluminum Wire
Side-Cutting Pliers
Long Nose Pliers
Step 2: Instructions to Make the Bracelet
1st, you need two golden aluminum wires and fold them in half. Then use a golden ribbon end to fix the wires.
2nd, thread blue beads on both outer sides of the bracelet before you make a cross.
3rd, repeat the second step and make the bracelet as long as you want. Use a ribbon end to finish the body of the bracelet.
4th, fix the golden lobster claw clasp and jump rings at both ribbon ends.
Step 3: Finish Your Bracelet and Share With Others!
Then the bracelet is made! Have you managed to make it? You can also choose other colorful beads to mix a new bracelet. Welcome to find jewelry making supplies and fun at Beebeecraft.com and share your crafts with us!
