Introduction: Beebeecraft DIY Project - How to Make a Blue 2-hole Seed Beads Stitch Bracelet
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Summary: Wanna try seed beads patterns? Check here! This Beebeecraft tutorial will show you how to make chic blue 2-hole seed beads bracelet for girls, hope you will like this handmade blue bracelet. Then details are listed as below.
Look at this chic seed beads and glass beads bracelet, do you like this style? If you are beading bracelets lover, today’s Beebeecraft tutorial on how to make fresh 2-hole seed beads bracelet for summer will catch your eyes a lot.
Step 1: Supplies Needed for This Blue Seed Beads Bracelet:
6x4mm Blue Faceted Abacus Glass Beads Strands
5x3.5x3mm LightSkyBlue 2-Hole Seed Beads
2mm silver 12/0 Glass Seed Beads
9mm Silver Color Spring Ring Necklace End Clasps
4~10mm Iron Jump Rings
0.2mm clear Fishing Thread Nylon Wire
Step 2: Make the First Part of the Blue Seed Beads Bracelet
1st, cut off a long piece of 0.2mm clear fish nylon thread and slide three 5x3.5x3mm blue 2-hole seed beads and two 2mm seed beads onto it, then cross the needle through the other hole of the 2 hole seed beads;
2nd, cross the fish wire through the hole of the 2 hole seed beads as the needle;
3rd, add one 2mm seed beads, 6x4mm blue faceted glass beads, one 2mm seed beads, three 5x3.5x3mm blue 2-hole seed beads, one 2mm seed beads, one 6x4mm blue faceted glass beads and one 2mm seed beads onto it with the needle;
4th, Make the part a circle as the picture.
Step 3: Make the Second Part of the Blue Seed Beads Bracelet
1st, cross a needle through the 2-hole seed beads;
2nd, add one 2mm seed beads, one 6x4mm blue faceted glass beads, three 2mm seed beads, one 6x4mm blue faceted glass beads, one 2mm seed beads onto it with the needle;
3rd, make these beads around the pattern; 4th, slide two more 2mm seed beads to the wire and place them the space between the 2 hole seed beads.
Step 4: Make the Third Part of the Blue Seed Beads Bracelet
1st, slide a 2mm silver seed bead, 6x4mm blue faceted glass beads and a 2mm seed beads of two end of the wire, and connect the 2 wire by crossing them through a 2mm seed bead (as shown in the picture);
2nd, fasten the beads to the pattern to make a new pattern;
3rd, slide one 2mm seed beads, one 6x4mm blue faceted glass beads, one 2mm seed beads, one 5x3.5x3mm lightskyblue 2-Hole seed beads, one 2mm seed beads and the same combination as the picture shows;
4th, continue to add the beads to make the same pattern as the first.
Step 5: Finish This Blue Seed Beads Bracelet
1st, continue to make more same beaded patterns and here 8 patterns have been finished, and you can decide the length according to you waist;
2nd, add jump ring and a lobster claw clasp onto the two ends.
Step 6: Now, Here Is the Final Look of the Blue Seed Beads Bracelet:
Have you got the skills of this blue seed beads bracelet making? And how is your project going? If you have any questions, please feel free to ask me or leave a comment. It’s super funny to make and you can find all materials on Beebeecraft. Hope you have a good time and welcome to share your masterpiece with us~
