Introduction: Beebeecraftideas on Making Elegant Pearl Earrings
Summary: Here, by using simply pearl beads, headpins and some jewelry findings bead spacers and cap, you can make beautiful dangle pearl earrings easily.
You should not miss this project if you are searching for a piece of easy pearl jewelry for your friends or yourselves. With a few simple tools and materials, you can DIY your own pearl drop earrings and create the exact match for your outfit. This beebeecraft craft tutorial is going to tell you the details on making the pearl dangle earrings.
Step 1: Craft Supplies for Jewelry Making Pearl Dangle Earrings:
BENECREAT 8 mm Round Glass Pearl Beads
3.5x0.7mm Platinum Brass Eye Pin
2mm Opaque colors glass seed beads
50x0.6mm 304 Stainless Steel Head pins
PandaHall Elite Platinum Filigree Flower Bead Caps
PandaHall Elite 6 Colors Iron Earring Hooks
BENECREAT jewelry making tools
Step 2: Make Pearl Dangles
1st, String one flower bead cap, a 8mm pearl bead and another sbead cap onto an eyepin and a 2mm seed bead onto another headpin;
2nd, Then, make a simple loop on the headpin and the eyepin another end by using round nose pliers;
3rd, slide 3cm brass chain to connect the 2mm seed bead and 8mm glass pearl bead as the picture shows;
4th, add an earring hook on the top to finish the pearl earring making.
Step 3: Make Another Same One in the Same Ways.
There is no need to buy some piece of pearl jewelry in boutique after you catch a sight of this pair of long dangling pearl earrings, just select the pearl beads of the size and colors u like and pins with an appropriate length, then you can make your own pearl earrings at home! You will enjoy and love them!
