Introduction: Beer Helmet -- Army Style
So during a heavy night of drinking about a year ago I came up with the bright idea of making a beer helmet, but use an army helment instead of the typical constructin helmet. Hungover as all hell the next day that is exactly what I did.
****WARNING: THIS IS MY FIRST INSTRUCTABLE SO IT HAS THE POTENTIAL TO BE VERY, VERY, GHETTO****
Step 1: Parts
*Army helmet (can pick up at any army navy store for like ten bucks)
*Plastic tubing
*T-connector for plastic tubing
*4 cup holders (I "borrowed" them from the local target that has a starbucks inside. Their idea is to clip these things onto carts to hold your coffee as you shop. My idea is to clip beer to my head).
*2 camo coozies
*8 cable ties (those velcro things that you use to keep your cables neat)
*Zip ties
***Please note that I built this thing a year ago and don't have pictures to document.
*Plastic tubing
*2 camo coozies
*Zip ties
Step 2: Attaching the Cup Holders:
As you can see there are four cup holders. Two have coozies attached and two don't. What is the of this purpose? Keggers of course! The front two cup holders are there for solo cups. When you don't beer in a bottle or can you switch the tubes to the front and you're good to go. This helmet makes you the macgyver of beer drinking.
To attach the cup holders use your velcro cable ties. Run the calbe ties through the precut holes in the camo fabric of the helmet and then through the cup holders themselves (this is hard to describe, check out the closeup).
Step 3: Attaching the Camo Coozies:
Now it's time to attach the coozies. I used a sharp knife to poke holes in them (three sets in each coozie) and then ran a zip tie through the coozie and around the cup holder.
Step 4: Run the Tubing...
This is the easiest part. I started by attaching the t-joint to the right side of the helmet (used zipties of course).
From the bottom of the t-joint I ran one but to my mouth, which was pretty short (eight inches at most). Next the top of the joint runs in a straight line to the back left coozie (which can be switched to the front left if there is a cup there).
Finally, I fan the back of the t joint around the back of the helmet and looped it back to the right side (once again this can go in either the right back coozie or the right front cup depending on which drinking mode you're in).
Step 5: Enjoy...and Some Improvements
So if you're like me when you're drunk you're:
a) Lazy
b) Proned to walk into things
So all in all this project satifies all my drunk criteria. I would like to note one improvement which would be adding a tip to the end of the drinking tube (much like you would find on a camel back). This would keep pressure in the system and eliminate a lot of foam issues.
I also wanted to get a first aid cross for it and make it a medic helmet (get it). It would be a pretty badass halloween custome, all you would need is a black t shirt and army pants fromt he thirft store. You'd be everyone's favorite guest.
Other than that I love my helment!
a) Lazy
