Introduction: Big Drinking Bird
This is a large drinking bird--made from a 3d scanned normal bird.
Step 1:
Start by painting the glass white on a normal drinking bird. Turn him on his head and scan. The hat is too thin to scan well, so I'll design a hat.
Step 2:
Print the body and head, enlarged about 350%.
Step 3:
Print the hat and axle. Files are available at http://www.thingiverse.com/thing:177456
Step 4:
Secure the bird's body using a screw (back side). Slide the axle over the tube, then secure the head with a screw.
Step 5:
Take a 1" x 2" by four feet long piece of oak and drill a 1 1/8" diameter hole in the center. Cut the board in half through the center of the hole.
Step 6:
Paint the "legs" your favorite color.
Step 7:
Design a foot in clay and scan it.
Step 8:
Merge the scanned foot with a designed base (I merge the STL files in TinkerCad).
Step 9:
Slide the legs into the base.
Step 10:
Glue googly eyes onto the head. Attach the hat by melting it to the head with a soldering iron (use good ventilation or outside).
Set the bird assembly onto the legs.
Give the bird a push every time you walk by--it will bob for about a minute.
