Introduction: Bitcoin Price Indicator Using Arduino
About: Engineering Student in India
Hello Guys :)
In this Instructables I am going to make Bitcoin Price Indicator . By Using Arduino
Bitcoin is the first cryptocurrency started in 2009 . Today Bitcoin become so popular . The Price of Bitcoin is
increasing exponentially . For that I made a Bitcoin Price Indicator . Each Time Bitcoin Price Changes . It
indicates with a BEEP sound
Step 1: Components Required:
Arduino UNO : 1
Buzzer : 1
For arduino you use any sort of arduino board you have . Because the main part is done by python program
Step 2: Circuit
I made a simple circuit by using TINKER CAD
Connect Buzzer Postive terminal to Pin Number 13 of Arduino
Connect Buzzer Negative terminal to Gnd Pin of Arduino
Connect Your arduino to your PC or Laptap via USB
Step 3: Uploading Arduino Code
First Open Arduino IDE
Go To ---> Examples ---> Communication ---> PhysicalPixel
Physical Pixel is a progam which make the digital pin high when it got a data H in serial Communication. If it got a data L it makes the digital pin low
Check the board type and port number and upload the program
Code Link
Step 4: Run Python Script
First Install All the Packags
requests pip install requests
pyserial pip install pyserial
beautifulsoups pip install bs4
Run the pip commands one by one in Command Prompt Run as administrator mode
Enter the Arduino Port Number in python program
This python program scrap the Bitcoin Price from the internet
This program will give the value of bitcoin each second
It will add the value of Bitcoin in list stored in variable price
Compare the current value with previous value
If it is not same . In the serial communication it will send word H it makes the Pin State High and after 2 seconds
It will send data L in the serial communication which makes the pin state Low
Code Link
Step 5: Sample Output
