Introduction: Black Balloon Burst With a Twist
This instructable and video combine the balloon in a balloon trick with the properties of a Phoenix green laser pointer from Wicked Lasers. Properties of the Phoenix and other lasers can be discussed at the laser forum.
"Posted by Laser Community member: tchplant"
Step 1: List of Materials.
You will need a black balloon, crystal clear balloon and a laser such as a 75mW Phoenix green laser. Buy your balloons in bulk. With all of the variations on this theme, you will be going through a lot of them.
Step 2: Preparing the Clear Balloon.
Using the Phoenix as a dowel, slip the clear balloon over the pointer and roll it up.
Step 3: Insert the Black Balloon.
Fold the black balloon in a way that allows you to partially insert it into the clear balloon you've just removed from the pointer.
Step 4: Encapsulate the Black Balloon
Unroll the clear balloon over the partially inserted black balloon, leaving the end of the black balloon exposed.
Step 5: Inflating the Balloons.
Blowing only into the black balloon, inflate both balloons as large as you can without bursting. Then tie-off the black balloon.
Step 6: Tying Off the Clear Balloon
Tuck the end of the black balloon into the clear balloon and tie-off the clear balloon. It is not necessary to further inflate the clear balloon.
Step 7: Bursting the Black Balloon.
Holding steady, direct the beam from the Phoenix laser pointer at the side of the combined balloons.
Step 8: The Result
The laser will pass through the clear balloon bursting the black balloon within, leaving you with the remnants of the black balloon within the inflated clear balloon.
