Introduction: Blue Light Blocking Glasses From Pill Bottles
So recently I read an article about how wearing orange glasses at night can help you sleep better at night. I wanted to test this for myself, and being the cheap person that I am, I made my own and it took me about an hour and a half. So yeah, that's what this instructable is.
Step 1: What It's Used For/How It Works
The basis of the science is that when you're exposed to sky blue light, it prevents the production of melatonin, which then interrupts your body's sleep cycle. Constant exposure to sky blue light at night-time, most commonly the LED backlight on screens and monitors, tells your body that it is still daytime. One way to reduce blue light at night is to wear orange glasses at night (hmmm I wonder how I would be able to make a pair).
Step 2: Tools and Materials
For this project, you will need:
- Pair of Sunglasses (or regular glasses)
- Orange Pill Bottles
- Big Book
- Gloves
- Heat Gun
- Scissors
- Parchment Paper
- Sharpie
- Tape
- Regular Paper
- X-Acto Knife (optional)
- Hand Saw (optional)
Step 3: What Color of Pill Bottles to Use (Optional)
If you happen to have pill bottles in more than 1 shade of orange, there is a way to test which will work best (if you only have access to 1 color, then move on to the next step).
If you have normal vision and your monitor can display RGB, then the 2 spectra above will have a noticeable difference. The upper one has a normal color range, but the lower one has the color cyan removed. To test which color of pill bottle will work best, look through each pill bottle (so that your vision appears orange) at the 2 spectra. Choose the color of pill bottle where the spectra look the most alike (when looking through said pill bottle).
Step 4: Pop Lenses Out
For this first step, hold the frame in place and push the lens forward, gradually increasing pressure along and around the frame until it comes out. Do this for both of the lenses.
Step 5: Cut Open the Pill Bottles
Use your handsaw to remove the bottom of the bottle by sawing it off. Then, cut through the middle "hot dog" style to cut it in half vertically (only on one side). You can use scissors instead of the hand saw, you just have to cut it open vertically first, and then cut off the bottom.
Step 6: Flatten the Plastic
Flattening the plastic is much easier with two people, one to hold the plastic and one to operate the heat gun.
Before you turn on the heat gun, fold a piece of parchment paper in half and place it anywhere in the book. Line up the crease of the parchment paper with the crease of the book, and leave the book open.
Turn on the heat gun on low, and get someone else to hold the plastic (or the other way around). Make sure to wear gloves. The person holding the heat gun must slowly move it in a circular motion so the heat is distributed throughout the plastic. The person holding the plastic must slowly bend open the plastic as it gets warmer, and once you get it flat enough, place it in the book. How flat you want it depends on how curved the original lenses were. Once it is laying flat inside the book, close the book and stand on it (optional). After a minute or two, you can open the book and take the plastic out.
Step 7: Cut the Plastic Lenses Out
After you've flattened the plastic, trace the original lens on a piece of paper and cut it out. Make sure you press the paper against the lens to include the lens' curve in the tracing. Then, cut out the shape from the flattened plastic using the paper as a template. Remember, it is better to start out cutting it bigger than you need it to be, and the carefully trimming it down to size. As you trim it down to size, compare it to the original lens and check to see if it fits in the glasses frame yet.
Step 8: Pop New Plastic Lenses In
Once it is the correct size, push it in the same way you took it out in the beginning.
Step 9: Enjoy!
Now all you have to do is put these on at night and enjoy sleeping peacefully. If you liked this then vote for it in the contests!
Research and stuff:
Fix Your Sleep With Low Blue Light! by Multifarious
https://www.instructables.com/id/Fix-Your-Sleep-wi...
Blue Light Blocking Test Picture
https://blueblockglasses.com/blogs/news/36521601-h...
Regular Old Info Article
https://wellnessmama.com/15730/blue-light-blocking...
Article With That Nice Picture
