Introduction: Bluetooth Control Robot
About: love tinkering with arduino ,hardware programming ,home automation, waste to treasure, Art and craft, DIY
This is very easy to make and cheap robot you can get all the component on amazon and the app and sketch from playstore
Step 1: Component Needed
1.) 2 DC Geared Motors +Wheels (Bought it from amazon Rs.190)
2.)Chasis (From Amazon Rs.115)
3.)L293D IC Based DC Motor Control Board ( Amazon Rs.100)
4.) Caster Wheel (Amazon Rs.85)
5.)Battery bank (As per your power requirement I used 11000Ah cause i want to play more)(From flipkart Rs 650)
6.)Arduino UNO Board( You can use any board .I used Arduino Uno ) (From Amazon Rs 450)
7.)HC 05 Bluetooth Module(Amazon Rs.190)
8.)Jumper Wires Soldering Iron
9.) Arduino Bluetooth Control App from playstore (Because it is free and the amker also provide link to download the sketch which will work with the app. I have also uploaded the sketch with this instructable,Its just a modified version of the original sketch
Step 2: Connection
1.)Connect motor and caster wheel with the chasis
2.)Solder the jumper wires with motor (just take care of the polarity)
3.)Connect the motors to the motor control board (you will recognize automatically when you see the board its easy)
4.)Make a USB connector to give main supply to the board (Just cut you spare USB cables ,take care of the polarity)
5.)Now connect Motor control Board to arduino Uno (Refer the Pic)
Arduino Board
A1 -- 4
A2 -- 5
B1 -- 6
B2 -- 7
VCC- 5V
GND- GND
You can use other pins also accordingly you have to change the Sketch
6.)Connect Bluetooth Modue HC 05 to Arduino (Refer the Pic) (Do these connection after uploding sketch only or the sketch will not upload)
HC 05 Arduino
TX RX
RX TX
VCC 3.3V
GND GND
Step 3: Sketch and Other Details
1.)Upload the sketch to the board
2.)Download arduino bluetooth control on your mobile
Now In the app
Device 1 ON Motor 1 FWD
Device 2 ON Motor 1 Backward
Device 3 ON Motor 2 Fwd
Device 4 ON Motor 2 Backward
So for Fwd Movement Device 1 and 3 ON Other OFF
For Backward Movement Device 2 and 4 ON Other OFF
Like wise left and right
This is the best free app i got on play store and since Am not an app developer i am just using it
you can search for more apps or can modify the sketch for better control
In the next Instructable i will tell you how to connect the robot to internet so that you can control it from anywhere (Thats why i haven't done much research on Bluetooth app and sketch)
Video for internet controlled robot controlled via website (Will upload the instructions shortly)
