Introduction: Sniper Rifle
HERE IT IS!!!!! My 5 shot sniper rifle. I made a few changes since the slide show, like a new trigger,and upgrading the strength a bit. Well then lets get started. If you get stuck ask me in the comments.
CHECK OUT THE NEW SIDE ARM https://www.instructables.com/id/The-Rhino-Pistol/
Step 1: Bi-pod
I dont know if this is a bi-pod. It has four stands. maybe its a quadropod any way it props up the gun. Its pretty simple to make just follow the pics!
Step 2: Mag
Here is the mag also pretty easy just follow the pics.
Step 3: Barrel
Here is the barrel.
1.make
2.add
3.add
make 6 of these
4-5.put together like this
6.make
7.add
8.make
9.add
10.make
11.add
12.make 2 of these
13.add
14.make
15.add white rods
16.add
1.make
2.add
3.add
make 6 of these
6.make
7.add
8.make
9.add
10.make
11.add
12.make 2 of these
13.add
14.make
15.add white rods
16.add
Step 4: Stock and Handel
This is pretty easy. Just put together. Follow the pics.
Step 5: Scope
Simple
Step 6: Trigger
Also simple
Step 7: Main Body
this is confusing but if you follow the pics you should be able to make it. As I said before if you get stuck just ask me!!
Step 8: Putting It Together
Almost Done
1. add mag
2. add trigger
3. add stock
4. close up
5. make and add
6. aerial view
7. make and add
8. aerial view
9. add barrel
10. close up
11. add white rods for mag suport
12-13. build
14. add
15. mag pusher
16. put in mag
17. add scope
18. add bi pod or quadropod or whatever
19. connect like this
20. add connectors
21. build ram (remember to add elastic and tape well)
22. add blue rod
23. put ram into gun
24. add blue connector
1. add mag
2. add trigger
3. add stock
4. close up
5. make and add
6. aerial view
7. make and add
8. aerial view
9. add barrel
10. close up
12-13. build
14. add
15. mag pusher
16. put in mag
17. add scope
20. add connectors
22. add blue rod
Step 9: Rubber Band Placement and Loading
For this gun I only use 1 elastic band for the ram, but you can use more. In total you need 3 elastic bands 1 for ram, 1 for trigger and 1 for mag.
1. rubber band
2. get elastic and put 1 twist in it
3. fold over like this
4. put on gun like this
Loading: this gun has a mag that holds 5 blue rods.
5. ammo
6. put in mag
7. insert mag pusher
8. add blue rod
9. add rubber band
10. pull band over like this and connect to blue rod on opposite side.
11.add elastic for ram
YOU ARE DONE!!!!!!
HOPE YOU LIKE IT!!!!!
1. rubber band
5. ammo
6. put in mag
8. add blue rod
9. add rubber band
YOU ARE DONE!!!!!!
Step 10: One More Thing
Wait one more thing. How to put the bi pod or what ever up.
Well all you have to do is open it and add white rods.
and one more thing people are getting confused on how to hold it well look at the pic.
HOPE YOU LIKE IT :)!!!!
Don't Forget To Rate!!!
