Introduction: Box Food Dehydrator
Inspired by the Food Jammers, these are plans for a food dehydrator based on the one they used to dehydrate a turkey. Mine will mostly be used for fruits and jerky but you can literally dehydrate anything with it and if you have access to a junkyard and thrift stores you can find a lot of the major supplies for cheap making the whole project less than $30.
Step 1: Tools and Supplies
Tools
Circular/ table saw - not really needed if you have a lumber yard that will cut to size for you
Power drill
Wire cutter
Plywood- preferably 3/4 in thick. I used 1/2 in and it worked fine though
metal racks- For the shelves, I went to a local recycling center. They were nice enough to let me dig through their pile of appliances and random metal. There I found 5 racks out of old ovens and had them cut down so they were all similar sizes. they sold me all five for a $1 so I couldn't complain with that.
light sockets
wall plug in
wire- i used 12 guage, probably could use something smaller
cabinet hinges
some type of closing mechanism- I took a metal clamp off an old grill that works great to hold the door closed
small fan - You can usually fine these for cheap at any thrift store
light bulbs
optional
wire mesh- I live in an area where there are a lot of bugs, therefore I put mesh on the air holes to keep them out
Step 2: Cut Wood Panels
Figure our the size you want your dehydrator to be and cut the panels to size. Mine ended up being 19" by 16" because that was the size that fit my shelves. I left the height a 4' so I wouldn't have to cut down the plywood from it's original size. The leftover wood I used to cut feet and holders for the shelves.
Step 3: Assemble Box
In hindsight, I should have placed the shelf holders on the panels before assembling. Use screws to assemble the box. and use the hinges to attach the front door panel. It might be easier to drill you air holes before assembling as well. The largest drill bit I had on hand was 1/2" so I drilled five 1/2" holes in the top panel and 5 holes on a bottom corner of the back panel for circulation.
Step 4: Wire Light Sockets
The only experience I had with wiring was from high school when I took home maintenance, which is basically none. I asked my local hardware stores if they had any tips and they all said they couldn't tell me anything for liability purposes. After looking around for tips online, I figured that would try using a daisy chain pattern.
This is a pretty basic wiring set up. Having little to no experience in this I will describe it the best I can. Starting from the wall plug in, connect the black and white wires from the plug in to short pieces of black and white wires respectively. For the rest of this I'll just talk about one wire but it's the same for both the white and black. To the short wire you connected to the plug in, using a twist on wire connector connect two short wires. One of these will go to your first light socket, the other use another twist on wire connector to connect 2 more wires. One of these goes to your second light socket and the other goes to the third.
I'm not good at describing this kind of thing but I hope the pictures help.
Step 5: Put It All Together
Place the lights and fan in the base of the box. I use 100W light bulbs and when I did a test run without the shelves the box held at 125 degrees Fahrenheit . I placed shelved 6" apart but you could do closer for more shelves. Right now I have watermelon and pears in mine. most fruits from what I have heard will take 24+ hours but I'm still experimenting. Good luck and enjoy!
