Introduction: Brass Ring With Silver Nugget
This is a simple brass ring with a silver nugget soldered on top. You will need brass and silver as materials.
Step 1: The Materials
Materials for this project are brass wire of gage 14 and silver nuggets. I get mine when I cast some silver parts. Usually, when you cast silver, the people who do this, do multiple pieces at a time, attached by small sticks. When they give you the parts back (in silver), they have this stick attached to them and cut off by cutters. This is what makes this pointy shape. So I used to keep these parts, and one day, I realized they would make awesome embellishments on a ring!
Step 2: The Tools for Forming
For cutting and filing:
- Cutters
- Pliers
- Files (large and small)
- Dremel with sand paper bit
- Sand paper
For forming:
- Ring mandrel
- Hammer
- Cutters
- Pliers
- Sand paper
For forming:
- Ring mandrel
- Hammer
Step 3: Tools for Soldering and Pickling
For soldering:
- Soldering tweezer
- Soldering pik
- Solder (silver)
- Flux
- Ceramic tile
- Torch (I use a whale torch with a small propane tank)
For pickling:
- Pot and stove
- White vinegar (serves to replace the chemical pickling typically used. I just prefer this because it is something I can get easily and it works well with my flux)
- Bucket of water
- Soldering tweezer
- Soldering pik
- Solder (silver)
- Flux
- Ceramic tile
For pickling:
- Pot and stove
- Bucket of water
Step 4: Start by Forming the Ring
First, cut a piece of the brass wire. Use pliers and your fingers to make it round. Make sure that it is flat and that the two ends touch very well. (the two ends have to be completely flat. Remember that the solder will not fill in any gaps, it will simply attach the parts that already touch). Finally, make sure that it is the right size on the mandrel.
Step 5: Solder the Ring
To solder the ring:
1- Cut small squares of the medium silver solder. Use medium because when you will add the nugget, you will reheat the ring and you don't want to melt this solder. At that time, you will use the easy solder.
2- Place the ring on the ceramic tile and add flux on the joint.
3- Heat the ring until the flux becomes white and then transparent.
4- Heat the solder quickly and put the pik on it to pick it up. Place the solder on the joint.
5- Heat the ring constantly, making circles. You don't need to focus only on the solder part, the whole ring needs to stay hot.
6- When it is hot enough, the solder will flow in the joint.
Step 6: Pickle the Ring
Before continuing, pickle the ring to dilute and clean the extra flux.
Put about 2 cm of vinegar in a pot and heat it a low on the stove. Place the ring in the solution until it is clean. Take it out and wash it in water.
Step 7: Shape the Ring
Once the ring is clear, you need to shape it.
1- Put the ring on the mandrel.
2- Hammer it gently until it becomes perfectly round.
3- Place the ring on a hard flat surface and hammer it to flatten the wire.
4- To finish this and make it more flat, use a file to make everything straight and at the thickness you prefer.
5- Use sand paper to remove the roughness of the filing. I use 400, 800 and finish with 1000.
6- Prepare the nugget by filing rough edges.
Step 8: Solder the Silver Nugget Onto the Ring
This is the exciting part! Putting the two together!!
1- Put the nugget down facing on the ceramic tile.
2- Place the ring on top and use the tweezers to hold it in place. Make sure that your setup won't move when you start the torch.
3- Add flux to the joint.
4- Start to heat the ring and the nugget until the flux goes white and then transparent.
5- Add a small square of the easy solder.
6- Heat the whole ring and focus a bit more on the nugget until the solder melts and flows in the joint.
7- Pickle the ring. Follow the same steps as show in step 6.
Step 9: Finishing Up!
Once the ring is clean and out of the pickling solution, it is time to make it pretty!
1- Use small files or sand paper to make sure nothing is too pointy or rough.
2- Use the dremel to polish the inside of the ring.
3- For all sand paper, always start with more rough (400) and then make your way to more smooth (800 and 1000).
4- Final touch: Use the brass brush with soap under the water to give a really shiny finish to the ring. I always do this instead of using polishing paste... it is just more easy and I find the result is almost the same.
Step 10: ENJOY!
This is it! Enjoy your ring or give it to someone you love!
