Introduction: Breadboards for Beginners
I see many Instructables, and other electronic projects using breadboards nowadays. Some people might think, "what is that?", or "How do I use it?" This Instructable will be used to help you answer those questions!
Breadboards are used for testing and experimenting with electronic circuits. I find them extremely convenient because they require absolutely NO soldering, and you just have to plug the component into the little holes that are provided on the breadboard.
Iguana Labs gave a few of these pictures and explanations. Thanks Iguana Labs!
Step 1: The Breadboard Connections
Breadboards consist of tiny "holes" in which the leads of the component connect into. Make sure that if you are using wire, use wire links, not the stranded wire, because it will crumple in the holes and damage your breadboard.
The top and bottom rows (the rows indicated by the blue) and are usually the (+) and (-) power supply holes and these move horizontally across the breadboard, while the holes for the components move vertically Each hole is connected to the many metal strips that are running underneath.
Each wire forms a node. A node is a point in a circuit where two components are connected. Connections between different components are formed by putting their legs in a common node. On the bread board, a node is the row of holes that are connected by the strip of metal underneath.
The long top and bottom row of holes are usually used for power supply connections.
Step 2: Connecting the Components
The rest of the circuit is built by placing components and connecting them together with jumper wires. Then when a path is formed by wires and components from the positive supply node to the negative supply node, we can turn on the power and current flows through the path and the circuit comes alive.
For chips with many legs (ICs), place them in the middle of the board so that half of the legs are on one side of the middle line and half are on the other side.
A complete circuit might look like the one below.
Step 3: Building a Circuit on the Breadboard
The circuit schematic, and the layout on the breadboard will turn out entirely different. Anyone using a breadboard must focus on the connections rather than their place on the schematic.
When you use switches or potentiometers, you must use single-core plastic-coated wire of 0.6mm diameter (the standard size). Stranded wire is not suitable because it will crumple when pushed into a hole and it may damage the board if strands break off.
