Introduction: Breakfast Sandwich: 5 Easy Steps to Make a Great Breakfast
This is a great way to make a easy breakfast for people to make in the morning
Step 1: Step 1: Make the Bacon
You first want to take 2 pieces of bacon and put them on your pan. You want to do this first because you need to rest the bacon. Once you have flipped it and it is good to go, you want to put it on a kitchen towel so the oil and fat can soak in it. After you are done that you can leave it on the side and go on to the next step.
Step 2: Step 2: the Bread
When making this you want to have English muffins. Cut the muffins in half and add a layer of butter on each side. Once you have done that you put it into the toaster and leave it there for around 5 minutes. Once that is done you can leave it on a plate.
Step 3: Step 3: Making the Egg
First, you want to separate your egg yolk and egg white, we will only be using the egg white. Once you have separated it you most likely want to have your egg whites in something you that is easy to control and pour. Next, you want to spray your pan with Pam and place the mason jar cap on top. Make sure that the jar is also sprayed so the egg doesn't stick. Once you have done that pour you egg into the hole, as soon as you do that you want to get a little bit of water and pour it in. This will baste the egg and cook it evenly. You then wait for around 1 minute and the egg should fall out. Then go place the circular egg on top of one English Muffin.
Step 4: Step 4: Adding the Toppings
For this part, you can be flexible with it. In this case, I only used a slice of cheese but you can add a wide variety of any topics you would like. Anything would probably work but for the most part, you should add bacon and the egg. Other than that you can add any other topics you would like.
Step 5: Step 5: Putting It Together
When you are putting it together you want to have you English Muffins on a plate. Once you have done that the first thing you want to add is you egg. Put you egg on one side of the English Muffin. After that grab your toppings and put them on top of the egg. Next you want to take your pieces of bacon and rest them on top of the toppings. Finally add your other half of the English Muffin and your breakfast sandwich is now ready.
