Introduction: Bridging the Gap With a Suspension Bridge Model.
About: I AM AN AVID READER AND ELECTRONICS ENTHUSIAST. I'm pursuing B.Tech C.S.E. from DIT UNIVERSITY, Dehradun. Right now, I have been investing my time in doing something productive and building something that matt…
This suspension bridge model is a compact yet functional representation of an iconic engineering marvel, designed with precision to showcase the key principles of structural mechanics in a visually appealing format. The model emphasizes simplicity and innovation, all while maintaining essential design elements of a real-world suspension bridge. The project aims to demonstrate the balance between strength, aesthetics, and scale
Two engineering facts:
1) On this kind of bridge, the suspender cables are meant to be vertical. This means they are pulling straight up on the deck so there is no sideways tension in the deck. You might have to tie the loops to the main cables to make them stay in the right place.
2) If you hold a piece of string from both ends and let it hang downwards with nothing attached to it, it will create the shape that the finished bridge's cable should have- you can then copy this shape to a piece of paper or cardboard and use it to figure out how long the suspender cables should be. This shape is also the shape of an ideal arch bridge upside down- I used this technique to help a friend build a brick arch for a pizza oven :)
Technically it isn't a parabola, it's a catenary(the curve that a flexible, uniform chain or cable assumes when it hangs freely from two fixed points and is acted upon by gravity), but they look very similar and a parabola is a good approximation to a catenary at this scale.
Know the terms before advancing further:-
Tensile strength
It is a material’s ability to withstand tension, or pulling. Cable is a material designed to have tensile strength.
Compressive strength
It is a material’s ability to keep its shape under pressure. A stone arch is a structure that only uses compressive strength.
To construct the suspension bridge model, the following materials were used:
  1. - Hard Cardboard: For the main structure, towers, and roadbed
  2. - Red Paint: To color the entire bridge for a bold and striking appearance
  3. - Black Paint: To create the road surface on the deck of the bridge
  4. - Wires (black or metallic): For simulating the suspension cables on both sides of the bridge
  5. - Glue or Adhesive: To bond the parts together securely
  6. - Scissors and Craft Knife: For precise cutting of the cardboard and wires
  7. - Ruler and Protractor: For accurate measurements and angle measurements
  8. - Optional: Small weight or sandbag (for testing load capacity)
Step 1: Design Concept
The design of this suspension bridge model focuses on achieving a balance between structural integrity and aesthetics while keeping the model small and compact.. The red color scheme enhances the visual appeal, while the black road adds realism to the overall design.
  1. Scale: The model is built to a scale that showcases the bridge’s key features without compromising its simplicity.
  2. Compactness: Maintain a small, portable design suitable for the contest’s requirements.
  3. Aesthetic appeal: The red coloring and black road create a visually striking contrast that enhances the model’s appearance.
  4. Functionality: Represent key components like the suspension cables, deck, and towers realistically.
Step 2: Constructing the Towers and Deck
Towers: Two vertical support towers were created by cutting and shaping hard cardboard into triangular forms. These were then glued together to create a stable and symmetrical structure. The towers are painted in red to match the rest of the model.
Roadbed (Deck): A flat surface was created by cutting hard cardboard into a rectangular shape. The road was painted black to simulate the driving surface of the bridge, adding a realistic touch to the model.
Angle Considerations: The angle of the towers and the cables was designed to mimic a real-world suspension bridge’s catenary curve, ensuring that the tension in the cables is distributed properly.
Step 3: Installing the Suspension Cables
Cables: Black wires were used to simulate the suspension cables on both sides of the bridge. These were carefully measured, cut to size, and glued in place to resemble the characteristic curve of the cables.
Support Mechanism: The cables were attached at the top of the towers, with the free ends anchored on the base at both ends of the bridge. This mimics the tension and load distribution seen in real suspension bridges.
Detailing: To ensure the wires stayed taut and realistic, small clips or adhesive were used to hold them in place, ensuring the suspension system visually resembles that of larger, real-world suspension bridges.
Step 4: Assembling the Model
After constructing the towers, roadbed, and suspension cables, the pieces were assembled to form the complete bridge structure:
Alignment: The towers were positioned vertically and secured in place using glue. The roadbed was aligned with the towers, ensuring it was horizontal and stable.
Final Assembly: The suspension wires were attached carefully on both sides of the roadbed to create a stable, balanced structure.
Step 5: Testing and Final Adjustments
Once assembled, the model underwent a series of tests to ensure its stability and functionality:
Load Testing: Small weights were applied to the center of the bridge to simulate traffic load. The model was observed for any signs of sagging or structural failure.
Aesthetic Adjustments: The final adjustments included painting touch-ups and ensuring all parts were securely glued together.
Step 6: Design and Innovation Features
Compact Size with Full Functionality: The model demonstrates key suspension bridge features in a compact form, maintaining functionality while adhering to the contest’s small size requirement.
Strong Aesthetic Appeal: The red coloring contrasts with the black road and cables, making the model visually striking and appealing from all angles.
Structural Integrity: Despite its small size, the model remains stable under moderate loads, showcasing careful consideration of structural mechanics within a compact space.
Simplicity and Precision: The use of hard cardboard allows for precise, clean edges and easy assembly, while the wire cables add a realistic touch without being too complex.
Step 7: Future Improvements
This suspension bridge model successfully combines engineering principles with aesthetic design to create a small but functional representation of a real-world suspension bridge. The compact size, vibrant red coloring, and realistic features, such as the black road and suspension wires, not only meet the contest's criteria but also highlight the creativity and innovation behind the design.
By focusing on both structural integrity and visual appeal, this model stands out as a prime example of how a simple, small-scale project can capture the essence of a large, complex structure. The use of cardboard and basic materials ensures that the project is cost-effective while still being visually impactful and structurally sound.
While the current model is highly functional and visually appealing, future iterations could include:
  1. Incorporation of LED lights to simulate lighting along the bridge.
  2. Dynamic load testing with heavier weights to explore the model’s performance under more realistic conditions.
  3. Additional structural details like pedestrian walkways or advanced cable detailing.
Hi there, pioneers! Now is your chance to build a miniature version of this suspension bridge model.
Good luck with your project!
