Introduction: Brother CS6000i Sewing Machine Setup
About: inventHQ is the Broomfield Library's makerspace. It is a place to invent, learn, play, and build community. Programming is offered for all ages and a wide variety of interests. Tools in the space include a las…
This guide will walk you through the upper and lower threading of the machine.
Step 1: Raise the Presser Foot and Needle
Make sure the presser foot and needle are raised. This will make the rest of the process easier.
Step 2: Setup Machine Support
Locate either the thread stand or cup behind the machine. These machines work better with less tension on the thread. Through trial and error, we’ve found that using a thread stand or cup to hold the thread works best.
Step 3: Setup Machine Support
Place the thread on the thread stand or in the cup.
Step 4: Setup Machine Support
If using the thread stand, pull the thread through the metal loop at the top.
Step 5: Threading on the Machine
Pull the thread through the clip. There are written instructions on the machine and this is labeled as Step 1:
Step 6: Threading on the Machine
Pull the thread down the right-side slot, up the left side, through the hook, and down the left-side again. These will be labeled as steps 2, 3, 4 & 5 on the machine
Step 7: Threading the Needle
Pull the thread behind the small metal clip at the top of the needle.
Step 8: Threading the Needle
Gently push the thread through the needle. It may help to cut the thread for a fresh edge on the thread. If you’re unable to thread the needle, ask a staff member for assistance to use the auto-threader.
Step 9: Threading the Bobbin
The bobbin is often already threaded. If you see that the bobbin is low on thread or empty, you will need to add a new one.
Step 10: Threading the Bobbin
Push the slide cover to pop the right side of the plastic cover.
Step 11: Threading the Bobbin
Remove the plastic cover.
Step 12: Threading the Bobbin
Remove the used bobbin.
Step 13: Threading the Bobbin
Replace with a new bobbin or different bobbin color, and pull the thread out, and around following the blue line in the drawing.
Step 14: Threading the Bobbin
Replace the bobbin cover
Step 15: the Machine Is Now Threaded and Ready to Use.
