Introduction: Build Arduino IDE From GIT Sources on Ubuntu 16.04
The purpose of this Instructable is to build the Arduino IDE from GIT on a clean Ubuntu 16.04 computer. The development master branch (mainline) will be used.
A Windows Instructable is located here.
Prerequisites:
- A clean Ubuntu installation (Tested on Ubuntu 16.04 32 and 64 bit)
- At least 1GB disk space.
- Internet connection.
Let's start!
Step 1: Install Java
The first step is to install Java which is required to run the Arduino IDE.
1. Open a terminal. (CTRL+ALT+T)
Note: Copy and paste the commands below without the $ character into the terminal and press [Enter]):
2. Add the following PPA (Personal Package Archives) to install Oracle Java 8 which includes JDK8 and JRE8:
$ sudo add-apt-repository ppa:webupd8team/java $ sudo apt-get update $ sudo apt-get install oracle-java8-installer
Note: You should accept the license agreement by selecting: Yes:
[LEFT ARROW], [Enter]
3. Check the Java installation, for example:
$ java -version java version "1.8.0_101" Java(TM) SE Runtime Environment (build 1.8.0_101-b13) Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
Step 2: Install Ubuntu Development Tools
Install the following development packages:
$ sudo apt-get install ant gcc git make
Step 3: GIT Clone Arduino Source
Download the latest Arduino sources from the GIT master branch with the git clone command:
$ cd ~/Downloads $ git clone https://github.com/arduino/Arduino.git
Next time you can update to the latest sources with the git pull command and skip the git clone:
$ git pull
Step 4: Build Arduino Sources
Build the sources:
$ cd Arduino/build $ ant dist ... [input] Enter version number: [1.6.11] < Press [Enter]
# Be patient!
BUILD SUCCESSFUL Total time: 9 minutes 10 seconds
Step 5: Install Arduino
Create the following directory:
$ mkdir -p /home/$USER/.local/share/icons/hicolor/
Install Arduino:
$ cd linux/work/
$ ./install.sh
Optional:
Create a symbolic link for Arduino tools:
$ sudo ln -s /home/$USER/Downloads/Arduino/build/linux/work/arduino /usr/local/share/arduino-master
$ ls -la /usr/local/share/arduino-master
lrwxrwxrwx 1 root root 54 aug 10 22:51 /usr/local/share/arduino-master -> /home/erwin/Downloads/Arduino/build/linux/work/arduino
Step 6: Run the Arduino IDE
Double click on the Arduino IDE shortcut on the desktop.
Congratulations! Arduino mainline is now installed!
