Introduction: Build Your Own Mini Drill
About: Hi, I'm Steve! I'm a creative mind with a knack for technical skills—I can build just about anything you can dream up! From innovative projects to captivating designs, I bring ideas to life with passion and pr…
Hey! everyone My name is Steve .
Today i'm going to show you How to make a mini drill
You can use it for drilling pcb , wood & plastic etc
This drill can accept 0.8mm to 1.5mm drill bits
Click Here to See The Video
Let's Start
Step 1: Stuff I Used
" The motor link i've provided comes with all the set you need to build mini drill "
Step 2: Building
  • Clamp the pvc pipe on the tabe
  • Use a hot air gun to soft the pvc pipe
  • now insert the motor in the pvc
Step 3: Connection
  • Now connect 2 wire coming from motor to dc jack with screw driver
Step 4: Building Cap
  • I used 12mm MDF
  • Now cut a hole using a 23mm hole saw
  • Now drill 12mm hole in the center with step drill bit to fit the dc jack
Step 5: Installing the Cap
  • now glue the cap with dc jack using a super glue (as shown in the picture )
  • now again use a hot air gun to soft the pvc pipe
  • now insert the cap
Step 6: Bit Adapter Install
  • Now install the chunk on the shaft
  • now install the drill bit
Step 7: Running
  • i used my bench power supply to power this up
  • motor need 5v - 12v to run
You Just Made It
Now just Plug the power and enjoy
Thank you for visiting my Instructables Stay tuned for next Projects
